Vand router wireless TP-LINK ( TL-WR340G )- Pret 75 ron (transport inclus )
Software SpecificationStandardsIEEE 802.11g, IEEE 802.11bWireless Signal Rates With Automatic Fallback11g: Up to 54Mbps(dynamic)
11b: Up to 11Mbps(dynamic)
Frequency Range2.4-2.4835GHzWireless Transmit Power (MAX)17dBmModulation TechnologyIEEE 802.11b: DQPSK, DBPSK, DSSS, and CCKIEEE 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDMReceiver Sensitivity54M: -68dBm@10% PER11M: -85dBm@8% PER6M: -88dBm@10% PER1M: -90dBm@8% PER256K: -105dBm@8% PERWireless ModeAP Router ModeBridge mode (point-to-point / point to Multi-point)Wireless SecuritySSID Enable/DisableMAC Address Filter64/128/152-bit WEP EncryptionWPA/WPA2/WPA-PSK/WPA2-PSK (AES/TKIP) EncryptionHardware SpecificationInterface4 10/100M LAN Ports(RJ45)1 10/100M WAN Port(RJ45)Antenna3dBi Fixed Omni Directional AntennaPower Supply UnitInput: Localized to Country of SaleOutput: 9VAC / 0.8A Linear PSUOperating Temperature0?~40? (32?~104?)Storage Temperature-40?~70? (-40?~158?)Relative Humidity10% ~ 90%, Non CondensationStorage Humidity5%~95% Non-CondensingDimensions6.3 ?.0?.1in. (160?02?8 mm) (without antenna)
