se poate conecta wireless ipbox-ul cu un USB ADAPTER D-LINK DWL-G122 ?
exista drivere implementate in E2 ?
multumesc
multumesc
exista drivere si un plugins wifi,dar eu nu am reusit sa ma conectez!!
nici nu am mai incercat.
Exista daca cauti o sa il gasesti cu conditia usb stick sa fie....
WLanManager 0,1 Beta for cuberevo Ipbox HD Enigma2 by ipbox2008 before proceeding installation, verify that your compatible pen wireless or with the chip zydas
here Supported Zydas ZD1211 devices - Linux Wireless is compatible with the driver relative zd1211 or zd1211b
se pare ca nu este compatibil cu USB ADAPTER D-LINK DWL-G122 :sorry:
pacat....astepta si poate iese o noua versiuna!
eu am incercat cu un asus usb wireless,care merge perfect pe dreambox800!
din pacate nu il vede:( pe ipbox 900 si 9000
ZyDAS chipsets based wireless 802.11a/b/g devices
Manufacturer Form factor
PCI PCMCIA USB Access Point MiniPCI
3Com 3CRUSB10075
Abocom WUG2650
WUG2660
WUG2670
Acer WLAN-G-US1
Airlink+ AWLL3025
Airlink101 AWLL3026
Alfa AWUS036-SMA
AWUS036-Z
Allnet ALLSPOT Hotspot-Finder
AmbiCom WL54-USB
AOpen WL54 ?
AsiaRF AWUG2401
AWUHG2401
ASUS WL-159g
Bluecomm WL-2203S
Canyon CN-WF518
Comtrend CT-WN4320Z
DigitPro WA4020
Fiberline WL-400U
WL-410U
DrayTek Vigor550
Hama 00062786
00039741
Hawking HWU54D rev Z/Z2 *
IOGEAR GWU523
JAHT WN4054U v2.0 *
CC&C WL-2203
WL-2203S
Edimax EW-7317Ug
EW-7317UHg
Encore ENUWI-G-ZDPR
HardLink HW-2454U
iNexQ UR055g
LanReady WUB-1600
LevelOne WNC-0301USB
Longshine LCS-8131G
LCS-8131G2
LCS-8170
Olitec 000514
OvisLink WL-5480USB-50
WL-5480USB-80
Phoebe OCT11G-USB
Planex GW-US54GZ-WO
GW-US54Mini
Planet WL-U356
Pro-Nets US54GZ
Repotec RP-WU0402
Runtop WA4020
Safecom SWLU-5400
Siemens Gigaset 54
Sitecom WL-113
StarTech.com USB555WG
Surecom EP-9001-g A2 *
Sweex LC100040
Telegent TG54USB
TRENDware TEW-424UB A *
TEW-429UB
Trust NW-3100
TwinMOS G240
X-Micro XWL-11GUZX
Xnet UWG640E
Xterasys XN-3133G
Yakumo QuickWLAN
Z-Com XG-760A
Zonet ZEW2501
ZyXEL G-220
AG-225H
54 (68) 0 0 68 0 0
se pare ca asta va merge!! are si super pret!!
astazi ma duc la magazinele de specialitate si il cumpar,dupa care ma voi apuca de teste,binenteles daca il gasesc in magazine!
as vrea sa configerez wpa_suplicant.conf
nu am pus la modem wep,wpa..practic este posibil sa se lege si altii de la mine ,dar am schimbat softul la modem si am lasat deocamdata asa
WPA2-PSK/AES
ctrl_interface=/var/run/wpa_supplicant.socket
ap_scan=2
network={
ssid="nomerete"
scan_ssid=1
key_mgmt=WPA-PSK
proto=WPA2
pairwise=TKIP
group=TKIP
psk="passwordrete"
cum ar trebui configurat ?
wlan.sh l-am configurat
multumesc
daca mai foloseste cineva modem adsl-romtelecom alcatel speedtoch 585v6 wirelles ce var de soft are ?eu am acum 6.2.29.2,inainte am avut 7.4.1.7 doresc o imbunatatire a parametrilor:
Uptime: 0 days, 6:07:25
Modulation: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 509 / 4.095
Data Transferred (Sent/Received) [MB/MB]: 19,86 / 166,97
Output Power (Up/Down) [dBm]: -20,4294967291 / 5,5
Line Attenuation (Up/Down) [dB]: 10,0 / 16,0
SN Margin (Up/Down) [dB]: 14,5 / 30,0
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 10 / 0
FEC Errors (Up/Down): 105.858 / 0
CRC Errors (Up/Down): 3.332 / 0
HEC Errors (Up/Down): 18.066 / 0
cam asta imi arata acum.la receptor am dwdelay intre 300.00-800.00(chiar si peste milion) la fel ecm time.primesc in hop2
ei ! cu e , merge ?Quote:
Originally Posted by gogi [Only registered and activated users can see links. Click Here To Register...]
Am luat un stick Canyon CN-WF518 , e in lista de aici cu chipset recunoscut de ipbox. Puteti sa imi spuneti pasii de instalare? Am incercat sa instalez (imagine AAF F1 - ultima) din plugins WLAN MANAGER dar nu apare nicaieri in meniu.
Macar un link, o idee cit de mica? Nu gasesc chiar nimic relevant pe tot internetul.
o idee mica iti dau eu : pune usb wireless intr-un alt receptor,dream sau vu+ si va merge sigur :).(eu m-am plictisit de atitea incercari si mi-a reusit in final ,dar in alta combinatie....:) )
deci si eu am incercat la ipbox si trebuie sa configurezi niste fisiere care le gasesti in pluginul wireless instalat si care intr-adevar nu-l vezi in panel,trebuie sa-l cauti cu FTP-ul(asta am gasit ,,how to'' si eu la vremea cind am incercat)
