CCcamInfoPHP 0.8.6 DT4
DT4 CCcamInfoPHP - With GeoIP
22.11.09
- New parameter in config.php:
/ / Setting up a server for sending emails.
- $ SMTP = "" / / server name smtp / pop does not
- $ Smtp_port = "" / / server port smtp / normally 25
- $ Send_mail_from ="";// your email
- $ Mail_username = "" / / username if the server requires authentication
- $ Mail_password = "" / / password if the server requires authentication
- $ Clientmessageemail [] = array ("",""); / / email clients
- New features
- In the directory "flags" is a readme.txt file that explains how to add more images of flags of countries. If the image of the flag does not appear in the application, then it is because there is no image and has to add the directory "flags".
- You can send an email to all customers or only to a
- There is a form in the client details that allows you to configure your e-mail, or configure the parameters messageemail existing config.php
- Displays images of flags of the countries of the clients and servers
- View the geolocation of a client or server via google maps. To view just click the top banner.
Important: The config.php has a new parameter so do not use any previous version of
Gracias a zegato
Probat de mine....concluzia ....NU-mi place , binenteles e parerea mea.
Dece nu-mi place? ....pai daca sta mai mult de 30 de secunde dupa cccam si nu termina de acualizat datele, i-i da o fatala eroare....sic:D Sa zicem ca asta nu ar fi problema dar la capitolul drapele de state, ....e tare limitat. De romania nu stie si multe alte chestii de astea simple de aspect care fac tot zaharul la un programel....
Asezarea in pagina e mai buna. Comparativ cu versiunea precedenta, fonturile-s mai mari, default, fara sa le fac eu mai mari ca sa nu ma holbez ca proasta la niste litere minuscule( si nu am rezolutia decat 1280x1024) sunt tare curios ce vad cei care au rezolutii mai mari la monitoare.
DA in schimb frumoasa chestia cu GEO IP.....inteligenta si binevenita....dar pana una alta pe mine ma intereseaza ce face si cum face cccam-ul nu de unde sunt cele IP-uri pe care le am. Asta pot sa o aflu si altfel.
Una peste alta mai e de lucru la el...si pana atunci raman cu al meu.
No....versiunea asta mai proaspata ma face sa cred ca la urmatoarea versiune va fi chiar foarte bun programul.
A aparut :CCcamInfoPHP v0.8.6 (DT5)
asta, chiar merge mai are ceva butoane care nu sunt insemnate (nu sti la ce folosesc) si cateva ferestre care nu-s dimensionate corect in rest merge bine
