PKT mod 4.4 TDT rev1575
Enigma2 Team Ducktales Build rev1575 of 23/10/2009 Points Mod 4.4
E2 @ rev1575 Kathrein HD UFS910
Image is designed to be installed on a pendrive or hard sata
E2 changes compared to version 1483:
Submitted by TDT:
+ Videomode percent crash fix
+ Fix N24 hopefully an every other interlaced-progressive interpretertation miss.
+ + + Update libdvbsi
+ Fixed kernel build error
+ 8.2 upgrade twisted
+ Volume control at startup, some other fixes volume
+ [Enigma2_03102009] patch
+ Showiframe end a little bit earlier.
+ New webif using twisted.web
+ Add epg fix
+ Fix RemoteControl in webif
+ Added stty, netstat and traceroute to config
+ Force time sync with the transponder
Submitted by PKT:
+ Expanded menu, "Standby" about the possibility of Polish days a week in standby mode
+ Updated Picon
+ Added PKT locale [Ar] [Lt.]
+ Added standby moderate
+ Improved network discovery menu, e2
+ Testsieci at the BP in terms of network problems
+ Updated list of channels 12x1
+ Added translation of new entries
+ Set password: Kathrein
+ Removed the 570i mode initialization e2 (correctly detects the image on samsungach)
+ Improved fonts
+ Sleep improved USB drives
+ Set automated dnsów
+ Auto restart if requested by the GUI E2 GS
Am vrut sa testez aceasta imagine, dar de cand n-am mai pus vreun PKT am constatat cu surprindere ca nu mai stiu de unde se descarca emulatoare, cfg-uri etc Nu am gasit nicaeri.:dance:
Vezi ca la imag. PKT , trebuie sa apesi pe tasta "albastra" sa-ti apara meniul "Polish Team....." - Plugins - Plugins Browser - Tasta Verde - emu
Pt. incubus vezi ca are numai vers. 0.87 si 0.88 complete , la v0.93 lipseste incubus.config
Functioneaza bine cu incubus v0.88 , si pot "mounta" manual sdb1 sau sdb2
In schimb nu am gasit fisierul pt. modificarea bootari cu hdd-ul conectat ( pe usb ) , ca la celelalte imagini
