Enigma 2 Nightly Build: 0.6.0 version
release 0.6.0
- fixed positioner setup using step diseqc command
- allowed 1080p 23,97 24 25 29,97 and 30Hz as display resolution
- fixed fastforward and seeking bug in mediaplayer
- added tuxtxt configuration file and a better readable font
- fixed fast forward in timeshift and playing recordings
- fixed slow-motion bug (micro-freezes on SD channels with 4:3 content)
- supported more HDMI tv using 576 output (edid bug should be fixed, report if some tv are not working during the wizard)
- supported MHW epg
- added:
/proc/stb/video/pal_h_start
/proc/stb/video/pal_h_end
/proc/stb/video/pal_v_start
/proc/stb/video/pal_v_end
- fixed a bug on volume value and changes
- fixed some memory leak bugs
- fixed a bug with dhcp
Here: [Only registered and activated users can see links. Click Here To Register...]
Re: Enigma 2 Nightly Build: 0.6.0 version
Am facut un test pe varianta FLASH a acestei versiuni ... varianta produsa
de echipa SWF ... test cu rezultate interesante !
- timpul de boot si in general manevrele de restart sensibil mai mare decat uzual
- am testat doua imagini IPBOX91 si IPBOX910 ... ambele functionale dar usor diferite ca implementare pannel ( 91 contine si MgCamd 1.33
dealtfel nefunctional ... din motive de referinta la libcrypto ..s-a rezolvat usor)
- la 91 inca nu s-a rezolvat problema indicatoarelor SNR-BER
- versiunea este foarte stabila ... cel putin in cele 3-4 ore de test s-a purtat peste asteptari atit sub incubus93 cat si sub mgcamd133
- nu are download server...asa ca emulatoarele sint deja incluse in imagine
- panelul porneste pe Blue Button ...si este destul de interesant
- gratie serverului unui prieten ... cu incubus am vazut TVRHD !!! Real-Milan fara nici cel mai mic ...sughitz !!!
Pentru cei interesati ... [Only registered and activated users can see links. Click Here To Register...]
Tnks @PETER36
