Patched modern images for dm800 clone
Load these images to internal flash
features
1-fix remote control poor performance
2-fix card readers problems
3-fix tuner problem
Warning:
we have three generations of dm800 clones
You should know which one you have before upload any image
first:secondstage bootloader 69
shortcuts BL69 or ss69
second: secondstage bootloader 70
اshortcuts BL70 او ss70
third secondstage bootloader 72,72
shortcuts BL72 او ss72
to know you dreambox BL version
1- At start of reboot there is number appears for short time at small screen,this is BL version
2- Put dreambox at setup or stop mode
unplug electical cord
plug it again while pressing the power button at front tell dreambox ip appears
then from pc
start-run-telnet ip dream
Note; do not care what about written in arabic in pictures,it is not important
if you do not know what your BL version then use images for BL69
"Load these image at your awn risk,i have tested only nabilo bh .11 for BL69 and it is working properly
for BL69:
for BL70
for BL 72:
SURSA: [Only registered and activated users can see links. Click Here To Register...]
