ce stiti se poate vedea in share pe astra19e ,si daca da pe ce frecventa ? (am cautat pe lyngsat si n-am gasit pachetul asta)
Great little topic.
And Nice work--thank you for sharing- for me this makes perfect sense though.
Canalele sunt astea, pachetul merge inshare atat cu gbox cat si cccam (cu 2.1.2).
Ca frecvente sunt aceleasi cu cele de la CanalSat France.
Se pare ca CCcam nu mai poate sa deschida TNTSat
TNTSat changed ECM length and CCcam cannot handle these new long ECM. Oscam team made the changes so for now, this card can only be used in Oscam.
Not sure if we will see a new CCcam that will solve this problem as it does not seem CCcam development is still alive...
Cam asa arata in oscam build #5400
Pe ultima versiune 5542Quote:
2011/07/05 22:15:00 2BE694B0 r [viaccess-reader] ECM: Invalid ECM structure. Rejecting
2011/07/05 22:15:00 2BE694B0 r Error processing ecm for caid 0500, srvid 20AE (servicename: TF 1 [V3&4]) on reader tnt.
2011/07/05 22:15:00 2FAE54B0 c TNT2 (0500&030B00/20AE/42:F6C2): not found (1 ms) by tnt (of 1 avail 1) - TF 1 [V3&4]
2011/07/05 22:17:23 2F6E54B0 c TNT3 (0500&030B00/20A5/42:B2AB): corrupt (301 ms) (of 0 avail 0) - FRANCE 2 [V3&4]
2011/07/05 22:17:48 2FAE54B0 c TNT2 (0500&030B00/4284/2A:B4E3): corrupt (301 ms) (of 0 avail 0) - NT1 [V3&4]
2011/07/05 22:18:23 2BE694B0 r Error processing ecm for caid 0500, srvid 200A (servicename: 0500:200A unknown) on reader tnt.
2011/07/05 22:54:23 2DEB54B0 c thread 2DEB54B0 ended!
2011/07/05 22:56:12 2DAB54B0 c incomplete request !
In oscam cu dvbapi deschide
Deci in CCcam s-a terminat....Quote:
2011/07/08 12:07:54 2CA8D4B0 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
2011/07/08 12:07:54 2CA8D4B0 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D8 PROVID: 003317
2011/07/08 12:07:54 2CA8D4B0 c dvbapi: [ADD PID 16] CAID: 0100 ECM_PID: 15D7 PROVID: 003315
2011/07/08 12:07:54 2CA8D4B0 c dvbapi: [ADD PID 17] CAID: 0100 ECM_PID: 15D6 PROVID: 003311
2011/07/08 12:07:54 2CA8D4B0 c dvbapi: new program number: 20A5 (1811:20A5 unknown)
2011/07/08 12:07:55 2CA8D4B0 c dvbapi: Start descrambling PID #4 (CAID: 0500) 1
2011/07/08 12:07:55 2CA8D4B0 c api (0500&030B00/20A5/142:82BF): found (215 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:08:04 2CA8D4B0 c api (0500&030B00/20A5/142:CDA3): found (214 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:08:15 2CA8D4B0 c api (0500&030B00/20A5/142:5E32): found (214 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:08:25 2CA8D4B0 c api (0500&030B00/20A5/142:BEFA): found (215 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:08:35 2CA8D4B0 c api (0500&030B00/20A5/142:7946): found (215 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:08:40 2CE8D4B0 c xxxxx: resolved ip=xxxxxxx
2011/07/08 12:08:40 2CE8D4B0 c encrypted camd35-client xxxxxxx granted (TNT2, au=off)
2011/07/08 12:08:40 2BE7D4B0 r Error processing ecm for caid 0500, srvid 2263 (servicename: 0500:2263 unknown) on reader tnt.
2011/07/08 12:08:40 2CE8D4B0 c TNT2 (0500&030B00/2263/C4:BE1A): not found (215 ms) by tnt (of 1 avail 1) - 0500:2263 unknown (key to use is not the curren
2011/07/08 12:08:45 2CA8D4B0 c api (0500&030B00/20A5/142:BCAB): found (215 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:08:55 2CA8D4B0 c api (0500&030B00/20A5/142:94BD): found (215 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:09:05 2CA8D4B0 c api (0500&030B00/20A5/142:E782): found (215 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:09:15 2CA8D4B0 c api (0500&030B00/20A5/142:2278): found (215 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
2011/07/08 12:09:25 2CA8D4B0 c api (0500&030B00/20A5/142:40E2): found (214 ms) by tnt (of 1 avail 1) - FRANCE 2 [V3&4]
