Am inteles ca merge cardul dolce in sharing.Care ar fi setarile ce trebuiesc facute sa nu fie probleme cu cardul.
SMARTCARD CLOCK FREQUENCY: /dev/sci0 5250000Quote:
Originally Posted by analogic [Only registered and activated users can see links. Click Here To Register...]
TRY ALL CHIDS : /dev/sci0
CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
BOXKEY: /dev/sci0 xx xx xx xx
B: /dev/sci0 00
PIN: /dev/sci0 0000
unde xx xx xx xx se gasesc astfel
nds box key find
serial nr of original box= adcdef1234567890
please use 123456789 in hex=75BCD15
from obtain use windows default scientific calculator put in decimal
and push hex to convert box key in hex,
add one 0 first digit= 075BCD15 this is the ready hex box key u can update by remote control "
adica pe romaneste din Identitatea receptorului (la dolce este in contract) care are mai multe cifre trebuie sa iei ultimele 10 cifre ,"scazi" (tai) ultima cifra deci numai "123456789 " (vezi ce e cu bold) si iti raman numai 9 cifre care trebuie convertite din sistem decimal in sistem hex cu windows calculator format scientific rezultand doar 7 caractere la care adaugi un zero " 0 " in fata ca sa fie 8 caractere xx xx xx xx
