Dm 800 : Pli enigma2 jade3
The PLi® [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] online Feeds and the [Only registered and activated users can see links. Click Here To Register...] downloads for the [Only registered and activated users can see links. Click Here To Register...] boxes are updated.
- Filenames: pli-enigma2-jade3-dmxxxx-20090719-6555.zip
Enigma2:
- EliteDVB repository Juli 18th 2009
- PLi® repository Juli 18th 2009
Drivers:
- Bootloader #61 for [Only registered and activated users can see links. Click Here To Register...] (Plus)
- 20090717 drivers for [Only registered and activated users can see links. Click Here To Register...] (Plus)
- Bootloader #73 for [Only registered and activated users can see links. Click Here To Register...]
- 20090707 drivers for [Only registered and activated users can see links. Click Here To Register...]
Plugins:
- Enigma2-Plugins: 20090716
Further:
- Several [Only registered and activated users can see links. Click Here To Register...] BSOD fixes
- TXT subtitle improvements
- Global [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] sets updated
- Ziggo [Only registered and activated users can see links. Click Here To Register...] updates
- [Only registered and activated users can see links. Click Here To Register...] install medium selection crash fix
- [Only registered and activated users can see links. Click Here To Register...] setting updates
- Gstreamer updates
- Streamproxy fix (improved streaming stability)
- [Only registered and activated users can see links. Click Here To Register...] settings crash fix
- [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] updated 2.1.2
Note:
- Softwaremanagement plugin doesn't yet work with most skins, old 'softwareupdate' and 'configbackup' plugins are still available
Use the downloadsection on our website to be sure to download our original PLi® images.
Warning:
Always backup your settings before attempting an online update.
- For the DM7025(+) it's better to flash your box again instead of updating via the menu
* (the changes are probably such that your box cannot handle the online update in filesize due to all differences)
If online update does not work out for you, download the lastest nfi, and reflash.
download :
