firewall-pli-dm500-V2R1
firewall v2 easy setup for gbox by OniK
script made by agecanonixeg
this is an quick easy setup please read
the readme for full infos
- backup /var/bin/firewall.sh
- put :
firewall.sh
firewall.resolve.sh
firewall.gbox.sh
in /var/bin and chmod 755
- if you want some log edit firewall.resolve.sh
line 48 :
# echo 1 > $GBOXFILE
Just remove the # to active firewall log.
log will be in /var/tmp/gbox_restart.log
- put :
firewall.dyndns
firewall.users
in /var/etc and chmod 644
In firewall.dyndns you must put all dyndns with dynamic IP.
In firewall.users you must put all static IP
(including the IP of your peers who have static IP)
- if you don't use crontabs :
telnet via dcc ...
contrab -e "enter"
press escape button on your keyboard
type command :wq "enter"
put root file in /var/spool/cron/crontabs and check the rights
they must be 600 (rw-------)
- if you are already using crontabs :
just add the line in the existing root file using command crontab -e
- To start firewall :
blue button
select system settings
service to run
select firewall and crond
save
-For info existing commands are :
firewall.sh stop
firewall.sh start
firewall.sh restart
now says byebye attacks........
Code:
V2 scripts for firewall.
! B E F O R E U S E R E A D A L L T H I S C A R E F U L Y !
Optimized for gbox Emu use.
============================= W A R N I N G =============================
All the scripts can be modify with an editor
but this must be done directly on the DM under linux
to keep the special linux characters compatibility.
If you don't, the scripts can be not executed.
Exist one solution to edit those scripts with a
standard editor on PC. ''
download :
