CCcam : line C: and line F: ........
'' As we all know C line gives the friend with whom the line changes with the F line connecting the C line sent to our server ....
F line necessarily must have a username and password (example: F: base gold fish), with the username and password usually goes and what gives reshare friend that is how he can send the received card behind, then gave the permits giving emu keys or not, then allowing a friend to send requests to EMM would updejtovao their card over net, then put the prohibition to use the C line sent to another DNS, or possibly a static IP, then the possibility of sending a non-sending cards and similar things, and time period in which a friend can use the sharing ..........
For these actions, it is necessary to configure CCcam cfg. in order to execute specified commands ........
Examples:
F: username password 2 1 1 (0:0:1)
give a friend a local map hop1 + + hop2
give him the keys emu
give him permission EMM sending request
with this option 0:0:1 friend will only be able to receive your card but without resharea
F: username password 2 1 1 (0:0:2)
with this option 0:0:2 friend will be able to receive your card and will have a reshare
F: username password 2 1 1 (0:0:3)
with this option 0:0:3 friend will be able to receive your card and have two reshare's behind
F: username password 2 1 1 (0:0:3, 093b: 0:1)
with this option a friend will have two-a reshare but caid (provider) 93b (Sky Italia new caid) will have no reshare a
F: username password 2 1 1 ([color = # 3100ff] 0:0:3, 093b: 0:1 (0100:000080:15 df))
with this option will not be visible or will have reshare for the program
F: username password 2 1 1 (0:0:1) () () friend dns
friends will be able to connect to your server only with the DNS or a static IP-a
F: username password 2 1 1 (0:0:1) () () (12:00-17:00, 19:00-20:00)
friends will be able to connect to your server in the above-mentioned time
F: username password 2 1 1 (0:0:3, 093b: 0)
with this option a friend will have two-a reshare but caid (provider) 93b (Sky Italia new caid) in no case will not receive
F: username password 2 1 1 ([color = # 3100ff] 0:0:3, [color = # ff3aff] [color = # ffa600] [color = # 00ffe1] [color = # ff7f00] 093b: 0:0)
with this option a friend will have two-a reshare but caid (provider) 93b (Sky Italia new caid) will not receive from your local ticket
F: username password 0 0 0 ([color = # 3100ff] 0:0:3, 093b: 0:1, 091:0)
give a friend the local map
do not give him the keys emu
do not give him permission EMM sending request
with this option will not be visible or will have reshare for this provider
C line
UC line necessarily have a DNS, the server port that is used, username and password ..........
Basic C line: C: server.dns.com 12000 username password
If you do not want to receive the keys of the peer: C: server.dns.com 12000 username password but
If you want to receive the keys of the peer: C: server.dns.com 12000 username password yes
Example C lines, which is receiving cards from hopa 2: C: server.dns.com 12000 username password no (0:0:2)
Example C lines, which is receiving cards from hopa 3 Sky Italia but receives only to hopa 1: C: server.dns.com 12000 username password no (0:0:3, 093b: 0:1)
Example C lines, which is receiving cards from hopa 3 but Sky Italia and Total TV does not receive local cards but only the cards of the above provider that he gets from his peer's: C: server.dns.com 12000 username password no (0:0: 3, 093b: 0:0, 0919:0:0)
Example C lines, which is receiving cards from hopa 3 but do not want to receive provider 093b - Sky Italia:
C: server.dns.com 12000 username password no (0:0:3, 093b: 0)
thnx @boshkarin ''
Re: CCcam : line C: and line F: ........
plz can you tell me how create c line or fine line and how do i create password and username? thanks
