Aici o sa gasiti toate firmware AB ENIGMA....
AB ENIGMA
AB Enigma1HD_9xxx_120609beta
This is Beta version of AB Enigma1HD for AB IPBox 9000HD/900HD/910HD and 91HD
How to install:
- unzip downloaded file to your PC
- Copy file from your PC into USB flash memory and rename it into "usb_update.img"
- IMPORTANT: Use "Safety remove USB device" function before disconnecting your USB flash memory from PC !
- Turn off your receiver (Standby+OK on front panel) and connect USB memory to USB (host) connector on your receiver.
- Press and hold Standby on front panel until "BOOTING" message appears on display,
press Up button . "USB UPGRADE" message should appear on display of your receiver - software update performs automatically.
- Wait until DONE message appears and restart your receiver.
How to install E2 HD (USB stick version) via internet with E1 HD installed inside box (Multiboot function):
- connect USB flash memory to receiver and formatt it to ext3
- go to Menu - Setup - System settings - Harddisc setup - line "connected"and make sure if USB is mounted to /hdd or /mnt/sda (if you don΄t have installed HDD) or to /mnt/sdb (if you have installed HDD)!!!
- press blue button and go to "tarx", press OK, and choose "Download Addon". You will see "Enigma2.sda" and "Enigma2.sdb" files for each model of HD boxes.
"Enigma2.sda" - choose only when you don΄t have installed HDD
"Enigma2.sdb"- choose only when you have installed HDD
- after choosing correct file, download will start and after that confirmation window will appear - press OK on "yes"
- when you will see window with "OK", you have successfully installed E2 HD on USB
- if you want run E2 HD just turn box off (Standby+OK on front panel),that press standby button and press and hold number 2 or 3 (it depends of installed HDD)
number 1 - booting from internal flash
number 2 - booting from sda
number 3 - booting from sdb
number 4 - booting from nfs
number9 - booting from set up enviroment 192.168.1.25 ipaddr,
192.168.1.102 server ip, nfsroot
/home/ipbox/rootfs
This can be helpfull:
- IMPORTANT: By manual searching of channels ever press "retune" after inserting all parameters.
This behavior differs from original E1, so don't forget about it when you need to do manual scan
- In Expert setup you can find "User reset" - this returns box to first setup with basic setting for 4 satellites
- In menu "Common Interface" you can find this: "can handle two services" - when you marked it to on, it is possible one scrambled channel record and one scrambled channel from same TP watch.
Note: this function must be also supported by CAM module!(e.g.Cryptoworks from Mascom supports this)
- If use 720p or 1080i mode with teletext, after teletext switch on, press Menu button and activate "true type fonts" item.
Please note that this is E1 HD, so in IP9000HD is supported only first tuner.
Known issues:
- DVB-C tuners not supported
- internal card readers don΄t work (external USB card readers work)
- works upper CI slot only, after inserting CAM module you have to restart it in menu of box. After every restarting of box you have to put out CAM from box and put in to box and reset CAM in menu of box.
- DVB and TXT subtitles are not working
- problem with formatting some 3,5" HDD΄s
- some bugs by playback recordings from HDD
- it is not possible timer recording from EPG
- SD menu graphic supported only
- installed games don΄t work in 720p and 1080i mode. (work in 576i and 576p mode)
- signal indicators don΄t work
- in some situations box doesn΄t present any channels, need reinsert CAM and reset CAM in Common Interface menu
NOTE: Source code of AB Enigma1HD will be released ASAP. Stay tuned
AB Enigma1HD_9xxx_150609beta
changes:
- fixed videoformat settings
- fixed S/PDIF, HDMI volume control
- add possibility change swap to other media (HDD, USB)
- add driver for card readers
- update Kernel 2.6.17.14 stm22 041 version with Open VPN support
AB Enigma1HD beta for AB IPBox HD/900HD
Changes:
Repaired/Added:
+ Added function of automatic HDD check after start *** Up button (from front panel).
+ Added card driver inside sw
+ Added Mgcamd with working configs to AIO panel
+ Added configs for 1 and 2 smartcard reader boxes to AIO panel
+ Edited setting with added Thor 1W and Astra 28.5E
+ Repaired Timer recording
+ Repaired signal indicators
+ Repaired displaying Nameserver and Gateway in network setup
+ Correct displaying CZ EPG when CZ or SK language of main menu selected
+ Added info bar "recording" on TV screen after start recording
+ Added wizard of video outputs after first booting, box automatic swithces between video outputs till one is confirmed.
+ Added TXT subtitles (turns on in audio track button) In 1080 mode you can change bigger font of displaying subtitles, but without diacritic (will be added in next version).
For change font, turn on teletext on any channel with TXT,
press MENU and mark "true type font", than exit menu.
+ Correct displaying time on front dislay after turning off (91HD)
+ Added button of quick restart by frozen box(for uni RCU 9000HD/910HD button "repeat"
under "RECORD" button, for RCU 91HD button "RECALL" between "MENU" and "EXIT")
+ Added welcome logo
Known Issues
- DVB-C tuner doesn´t work
- DVB subtitles are not working
- installed games don´t work in 720p and 1080i mode. (work in 576i and 576p mode)
- doesn´t work CIFS
- after start playback from HDD, picture breakdown - it is necessary start playback again
- When SHARP tuner is inside box - signal indicators don´t work
Next repairs, which will be solved:
- playback - ts, divx, mpeg
- dvb subtitles
- video scaling for 544x572 4:3
- other known issues
ipbox 900:
ipbox 9000:
ipbox 910:
ipbox 91:
