How to: Make CCCAM Work using Andlinux & Emubox
How to Make CCCAM Work using Andlinux & Emubox (For DVB PCI Cards)
'' Note :
Download Microsoft .Net Framework 3.5 SP1 Before doing all Below steps :
Download Andlinux Here :
1- On starting press on Next Then I accept the agreement.
2- choose the Location that u want Andlinux to be installed (For Example Drive D:\).
3- (andlinux Configuration Screen\Memory Size) : It's Recommended 192 MB or More .
4- (Do you want to enable sound for andlinux?) Choose (Yes).
5- (How do you want to start andlinux and lunch application?) Choose the last option : run andlinux automatically as NT service + use Windows shortcuts.
6- (How do you want to access your Windows file system from andlinux?) Choose the secound option : using CoFS (easy configuration).
7- (Please selecet the folder to mount via CoFS.) Choose (For Examble Drive D:\) so all files below this drive or folder can be accessed from andlinux.
8- Then keep doing next till last screen then press Install.
9- Restart your PC.
after step "9" andlinux is ready to be configured with CCCAM plugin.
Note : If you have any firewall programs disable Auto block setting in the program to make andlinux work with cccam & Emubox.
Download CCCAM Plugin :
Download Emubox Plugin :
1- Goto system tray then click on anlinux icon, it will appear like this :
2- click on "Thundar" this will appear
3-On "root" section there's a folder named Windows as appeared in the screenshot above, this folder is the drive which you choosed in step "7" Above which will be shown under andlinux.
4- After downloading CCCAM & Emubox extract Both RAR files in Folder for each and name it like this (For Example cccam2.0.11 & emubox) in (for examble Drive D:\) which will be shown when you click on folder (Windows) on "root" Section.
5- Then goto "File System" Section which will appear like this :
6- Do double click on this folder " var" then while you inside this folder goto "File" in Menu and choose "Create Folder" or "Shift+Ctrl+N" to create two folders one is "bin" and other is "etc".
7- Then goto "root" Section do double click on Folder Windows then do the following :
A-Open the folder (cccam2.0.11) then copy those files (CCcam.x86, CCcam.armeb,CCcam.armeb.eabi,CCcam.mipsel & CCcam.ppc) without the file (CCcam.cfg) then return to "File System" Section and open "var" folder then open the folder "bin" which you created before then goto "Edit" in menu and choose "paste".
B- Back again to "Windows" folder in "root" Section and open the folder (cccam2.0.11) then copy (CCcam.cfg) from "Edit" in menu, then return to "File System" Section and open "var" folder then open the folder "etc" which created before too then goto "Edit" in menu and choose "paste".
C- Now open the file (CCcam.cfg) by double click and clear all the information inside that file and paste your server (C: <hostname> <port> <username> <password>) and goto "File" in menu and choose "Save" then close the file.
D- Then return to the Windows folder again which in "root" Section and open the folder (emubox) then you will find two folders one is "windows" and other is "linux" open "linux" folder and copy those files (emubox_interceptor.cfg, emubox_interceptor.so, run_background & run_debug)then return to "File System" Section and open "var" folder then goto "Edit" in menu and choose "paste".
-After copying all files inside "bin" folder :
-And folder "etc" folder :
8-Like that we finished from andlinux now we can close (root-File Manager)
9-now it's time to copy DVB Player plugin form the path "D:\emubox\windows" which are (emubox_plugin.cfg & emubox_plugin.dll).
10-Edit the "emubox_plugin.cfg" using Notepad and on this section we will type this IP :
# emubox ip (virtual machine, colinux, or real machine)
server_ip=192.168.11.150
then do save and close the file.
11- Finally click on "andlinux menu" on System Tray and choose "Terminal" which it's like Dos system and type these commands exactly :
cd /var/bin/ Then Press (Enter)
chmod +x run_debug Then Press (Enter)
./run_debug -d Then Press (Enter)
12-Now you can open your DVB Player
[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Re: How to: Make CCCAM Work using Andlinux & Emubo
