Aici o sa gasesti pe E2 pt USB STICK
Aici e enigma 2 for 900/910!!!
Informatii pt install sunt inaitru la readme file.
ENIGMA 2 for ipbox HD/cuberevo/cuberevo-mini SIFTeam:
First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
Default settings are for single tuner on HotBird sat. (you can change them in the menu)
WARNING: Do not forget to change your DNS configuration (if you want to use the decoder on the net). The DNS configuration could only be made by editing manually the file "/etc/resolv.conf"
HISTORY:
release 0.1.0(beta):
This is the first public release, it's released as a beta version, probably it has many and many bugs, but to fix and to discover them I need all your help, so I decided to make it public
This version does not support:
- card reader
- DVB-T, DVB-C, DVB-S tuners
- twin tuner
Enjoy it! Tideglo
ABOUT ENIGMA 2 for ipbox9000/900/910/cuberevo/cuberevo-mini:
This is an adaption of Enigma 2 for the DGStation's High Definition boxes.
I want to thank these people:
Team DuckTales: for helping me on finding really many bugs and to helping me on make Enigma2 like it is now.
zbigzbig20: for default bootlogo
Spaeleus: for Italian translation
SIFTeam: this is my place, with all my friends that i like really to chat with!!!! (I LOVE YOU GUYS)
I want also to thank two special friends:
genge: for be the best betatester of ever!!!!! (really a ball breaker but also a good friend
PhotosOfGhosts: for helping me on finding, studying and solving bugs
Regards, Tideglo
HOW TO INSTALL:
To test this enigma2 image you need a running nfs server and a serial & network
connection to the receiver.
You need uboot 1.3.1 or higher to run e2 (never tested with lower versions)
Do this only if you want to use nfs-server otherwise go to point 3:
1. extract the tgz file on the server and set the directory in /etc/exports
for example:
/root/Desktop/root 192.168.1.0/255.255.255.0(rw,no_root_squash,sync,no_subtree_ch eck)
where 192.168.1.0 is your net base-address and 255.255.255.0 is your netmask
2. restart nfs server
3. connect via serial console with an hyperterminal connection to the receiver (I suggest you to use putty, it's freeware, and configure it to use a 115200 serial connection)
4. turn on the receiver and hit ctr+z in serial console
you should see the following prompt:
cuberevo>
5. customize the following settings to your network environment and type them into the
serial console:
setenv menu_1 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/nfs nfsroot=/root/Desktop/root rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd "nfs a5ff0000 192.168.1.6:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveenv;boot'
setenv menu_2 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
setenv menu_3 'setenv ipaddr 192.168.1.6;setenv serverip 192.168.1.1;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
setenv menu_4 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
saveenv
remember to customize where /root/Desktop/root is the directory you added to /etc/exports and ipaddr is the ip of your decoder, serverip is the ip of your nfs-server, gateway is your gateway ip, netmask is the mask of your home-net
6. now you can restart your decoder and press the relative remote controller's button for 5 seconds to start the image you want:
Press Button 1: start your image using nfs-server
Press Button 2: start your image using usb pendrive if you don't have a SATA hdd
Press Button 3: start your image using usb pendrive if you have a SATA hdd
Press Button 4: start your original flash image in the decoder (DGStation's original firmwares and images based on them)
That operation is necessary only the first time you want to change your boot commands. You don't need to press all the time you reboot the decoder a button to select wich image to start, simply do that only if you want to change to e2 nfs from usb, or from original images.
That's all, Tideglo
DOWNLOAD
Ipbox 9000
Ipbox 900/910
HISTORY:
release 0.2.0:
Bootargs are changed a little bit (simply removed the bygphysarea param), you can use the old one, or update them (doesn't matter if you update 'em or not)
What's new:
- support for:
- cuberevo-mini2 (cuberevo-3000HD/ipbox 910HD)
- cuberevo-mini (ipbox 900HD)
- cuberevo (ipbox 9000HD rel1 and rel2)
cuberevo-250hd (ipbox 91hd) and 200hd are not yet ready, i need more time, sorry
- support for multple tuners:
- dvb-s2 (samsung and new sharp tuners)
- dvb-s
- dvb-t
- dvb-c
- fix in epgcache to solve greenscreen in EPG->Similar Events
- improved resynchronization after fast forward
- added audio track selection for m2ts/trp/vob, after changing the audio track it might take 2-3 seconds for the sound to continue
- tuxtxt dont crash if no swap is used
- pictureplayer in fullscreen
- networktest working (not yet enabled the possibility to change by menu ipaddresses)
- added power-off function (to be tested better)
- busybox +ip addr +nslookup
- more exact seeking for m2ts/trp/vob on keys 1/3 4/6 7/9
- added mkv support
- volume up/down fix
- added dts playback
- support for twin tuners (to be tested better, working only live channels)
- added seeking with 1/3 4/6 7/9 keys for some avi files
- many HDMI related fixes
- added m2ts and trp file extensions support in mediaplayer
- Fixed CVBS, RGB, S-Video switching SCART mode
- Enable choose ColorFormat for HDMI, set Component to ColorFormat YUV as default
- added HDMI-PC custom resolutions
- fix the pictureviewer
- fix placing video picture on screen for Pig render. Skins with small video window now works.
- scart set widescreen flag if wanted
- fixed timer-bug
- mpeg-1, mp2, 23.976 fps work
- fixed the problem with low-bitrate streams
- aspect fix for channels like BBC HD with resolution 1440x1080
- mute should now work
- added streamproxy for streaming channels via lan
- changed webif to port 80
- fixed webif in many parts
- support for HD-Skins
- support for HD-Picons
- pyopenssl added
- fix dvd-player
- fixed HMDI, Scart detection
- firstboot will be done by Wizard
- fixed audio dropouts and video artefatcs
- fixed many remote controller handling (all buttons should now works)
- fixed possibility to change audio on channels by remote controller
- SPDIF out should be fixed
- added python bin
- fixed hdd format
- fixed hdparm (for hdd standby)
- default language is fixed to English
- added pl2303 driver (for external smart card reader)
- updated polish language (thank's to zbigzbig and crashs)
Consider also that any kind of mods are enabled, so everybody can do their own image, but please do not delete thanks and readme file.
All people collaborating had worked hard, so please let's have a little respect.
- card reader
- twin tuner
Enjoy it! Tideglo
zbigzbig20, crashs: for default bootlogo
Regards, Tideglo
HOW TO INSTALL:
for example:
cuberevo>
serial console:
Code:
setenv menu_1 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/nfs nfsroot=/root/Desktop/root rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd "nfs a5ff0000 192.168.1.6:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveenv;boot' setenv menu_2 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot' setenv menu_3 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot' setenv menu_4 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot' saveenv
That's all, Tideglo
Mini How to for Usb users:
English
1) connect the pen to the 9000
2) format the pen [Only registered and activated users can see links. Click Here To Register...] as for move var
3) disconnect and reconnect eh pen (so the [Only registered and activated users can see links. Click Here To Register...] see it)
4) copy with FTP the file tar.gz in /mnt/[Only registered and activated users can see links. Click Here To Register...]
5) enter in telnet
6) write cd /mnt/[Only registered and activated users can see links. Click Here To Register...]
7) write tar xzf nomedelfile.tar.gz
DOWNLOADS
SIFTEAM E2 0.2.0 (IPBOX 9000HD)
Pt usb stick:
SIFTEAM E2 0.2.0 (IPBOX 900HD)
Pt usb stick:
SIFTEAM E2 0.2.0 (IPBOX 910HD)
Pt usb stick:
release 0.3.0:
Now there's no more need to change bootargs, IPs will be set on Enigma2 Network Menu.
Bootargs are changed a bit more if you do not want to set anymore IPs on bootargs. Bitwise also old bootargs will work perfectly.
What's new:
- support for:
- cuberevo-mini-fta (cuberevo-200Hdt)
- cuberevo-250HD (ipbox 91HD)
- cuberevo-2000HD
- cuberevo-7000HD/9500HD
- added support for Common Interface modules (take in consideration that a CI cam will make slower Enigma2,
this will be fixed in future. Also do not forget that to the upper slot will work with Tuner1 and lower slot with Tuner2)
- fix for CSAT France HD Blackscreen
- fixed randomly occuring crash on e2 exit
- fix restarting if old timer still set
- fixed front panel display management
- fixed hour display
- fixed stanby
- fixed deepstandby
- fixed restart GUI
- fixed restart
- fixed HD channels bugs
- fixed many of the random artefacts on viewing channels
- changed keymap.xml, now we will use the Enigma-like functions for remote controller buttons
- updated cvs to 09022009
- added srt subtitle support
- added avi x264 support
- added avi h264 support
- added xvid 720p support
- fixed mv id3tag
- added wav support
- added 2nd scart input control
- fixed many HDMI bugs
- fixed fast forward, fast reward
- fixed audio track selection m2ts/vob/trp
- added CROND and CRONTAB
- fixed configuration Menu Network Setup (this will works only with USB and Flash version, NFS couldn't set IP for obvious reason)
- added tun.ko module (for VPN support)
- added/updated usb-serial converter support (pl2303, ftdi_sio)
- added ssa subtitle
- fixed ass subtitle
- enabled ntfs as module
- fix for HD skins
- fixed mkv + h264 sync
- implemented mp3 playback directly via http connection for plugins like last.fm
- added filextension pls
- fixed crash when tuner is not configured
- fixed crash when harddisk or stick connected
- fixed DVB subtitle position for HD skins
- fixed crash on entry manual tuning parameters when S2 is in use
- updated webif
- fixed support for large file playing
- fixed all scan problems and "No SID found in PAT" message
- support for Unicable/SCR based system
- many code optimizations and personalization for Cuberevo
Tuxtxt is enabled but not yet working good on the "pressing button" recognition, so pay attention on using it, you will need to restart e2.
ipbox 9000:
ipbox 910:
ipbox 900:
ipbox 91:
Only for ipbox 91hd use attached file (for others stb use standard procedure)
Multi-booting support as below only for 91hd.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
release 0.3.1:
- fixed the recognition of the DVB-C tuner when is present on the slot number 2
- fixed a bug on channels scan
- added flash version for all models
Ipbox 9000HD:
Ipbox 910HD:
Ipbox 91HD:
Ipbox 900HD:
release 0.3.3:
- fixed a bug on cuberevo-2000hd that caused no audio on all channels
- fixed many bugs on channels scan (hope now it's ok on all sat)
- first try to fix continue freezes bug after a real freeze happens
- fixed some wrong autoresolution bug on many channels (like BBC, csat fr, etc)
- new kernel version (2.6.17 p0041)
- new implementation for CI cams (still needs to use upper slot for first tuner and lower slot for second tuner, this will be fixed soon),
ow CI cams should use less cpu time and should rallenty less the enigma2 execution.
release 0.4.0:
- fixed boot image that was not shown every time on every TV
- revert back to python 2.5, now you can use all enigma2 plugins for
dreambox receivers wich do not have sources available and wich uses
only python files .
- fixed DHCP, now is working by network menu configuration
- added the option to enable DHCP also with nfs-server to load enigma2 (just change the kernel loading bootargs)
- fixed the overheading bug on date/time that caused to have always a wrong time/date
- fixed tuxtxt crashes and outputs management
- fixed the bug that causes Timezones outside of Europe not to work,
always reverts back to GMT time. All times over 3+ GMT and under GMT
did not work.
- spdif audio output on ipbox91hd/cuberevo250hd
- fixed subtitles on dreamtv-hd skin
- fixed aspect ratio: Pan&Scan and Pillar box settings reversed
- fixed menu selection options that were not selectable, like 8MHz bandwith selection, or many fec options
- fixed skin HD
- updated skin HD
- patch for white subtitles (i don't know if this is usefull or not, but i thought it's better to have a
white subtitle with black background, just more viewable)
- fixed EPG button (now you can choose wich kind of epg list to view)
- fixed deep standby broken since 0.3.3 (do not forget to delete all
wakeup timers from dgstation firmware, because if you forget it,
then the box will restart automatically!)
- added a Satellites configuration with all sat positions (if you think
there's something missed you can still add yourself configuration files)
- added a Terrestrial configuration to support almost all Europe providers (inserted general europe voice,
obiously i can't add a provider for each one on the worl, so just update the file if you need a specific provider)
- fixed some other channels scan bugs
- fixed menu Network test on the "link connection" voice
- fixed positioner menu crashes
- MediaPlayer Bug with a gsod on NoneType error using subtitles
- fixed rotor using diseqc
- reboot of enigma2 now should works good
- completed the kernel version p0041 adaption
- improved a bit CI cams manager
- fixed many memory bugs that caused the player to crash (let me know if you find more bugs on playing multimedia files)
- ipkg support, as soon as sifteam will have a download for ipk files
you will be able to download them from the browse plugin menu
- added by default the file /var/etc/rcS_user.sh that is called on
boot, so if you want to add any kind of command to be executed on start
just put them in this file
- patch for North American satellites (let me know if you find any kind of bugs)
ATTENTION:
if you are a NA user, do not forget to change in the "/etc/init.d/rcS" file this value:
insmod $MODDIR/stmfb.ko display0=1280x720-32@50:12M:PAL:YUV:RGB;
into:
insmod $MODDIR/stmfb.ko display0=1280x720-32@60:12M:NTSC:YUV:RGB;
This is needed to let you see the boot image and to have a full working display on TV.
Ok that's all, i know there are some other bugs to be fixed, but i think there were a lot of improvement in this version and
i'm working to some new drivers so i think before using the new drivers
we should test all these improvements and then see if something could
be better or not.
Ipbox 9000:
Ipbox 900:
Ipbox 910:
Ipbox 91:
ENIGMA 2 for all DGStation products:
- cuberevo-mini-fta (cuberevo-200hd)
- cuberevo-250hd (ipbox-91hd)
- cuberevo-mini (ipbox-900hd)
- cuberevo-mini2 (ipbox-910hd, cuberevo-3000hd, madtek-3000hd)
- cuberevo-2000hd
- cuberevo-9500hd (cuberevo-7000hd)
- cuberevo (ipbox-9000hd rel1 and rel2)
HISTORY:
release 0.4.1:
- fixed a bug on setting ip and dhcp on particular cases where dhcp server is off
ipbox 9000 USB STICK:
ipbox 900 USB STICK:
ipbox 910 USB STICK:
ipbox 91 USB STICK:
release 0.4.2:
- fixed the diseqc bug, one for all, on the ipbox-91hd/cuberevo-250hd, cuberevo-200hd and all models wich uses the sharp tuner
ipbox 9000
USB STICK:
ipbox 900
USB STICK:
IPBOX 910
USB STICK:
IPBOX 91
USB STICK:
- cuberevo-2000hd
HISTORY:
release 0.5.0:
- fixed a bug on rebooting the system
- better CI cams handling
- support for upper and lower CI slots on the current live tuner, no more needs to put the cam only on the upper one [Only registered and activated users can see links. Click Here To Register...]
- added new dvdplayer
- support for timeshift
- fixed alpha blending colour on images
- updated e2 cvs to 30/05/2009
- fixed fstab auto mounting for hdd
- vsftpd log on file disabled by default
- fixed a bit keymap for 250hd/200hd, audio subtitles now is mapped
- added autoload of epg (using myepg now the file will be loaded automatically at enigma2 restarts)
- some fixes on mediaplayer for some multimedia files
- many fixes all around for better stability, now i think most part of drivers are done
- updated arabic language
I know there are still some bugs that sometimes break our balls too much, but i'm trying to solve all, just wait and hope
the funniest thing is finding those bugs
I would like to thank all people around Enigma2 for cuberevo, many teams are making really great stuff, i like how cuberevo
community is going on, i think this is the spirit our box should be!
I would like also to thank people making really great plugins, we will win all together! [Only registered and activated users can see links. Click Here To Register...]
See you on next release.
release 0.6.0
- fixed positioner setup using step diseqc command
- allowed 1080p 23,97 24 25 29,97 and 30Hz as display resolution
- fixed fastforward and seeking bug in mediaplayer
- added tuxtxt configuration file and a better readable font
- fixed fast forward in timeshift and playing recordings
- fixed slow-motion bug (micro-freezes on SD channels with 4:3 content)
- supported more HDMI tv using 576 output (edid bug should be fixed, report if some tv are not working during the wizard)
- supported MHW epg
- added:
/proc/stb/video/pal_h_start
/proc/stb/video/pal_h_end
/proc/stb/video/pal_v_start
/proc/stb/video/pal_v_end
- fixed a bug on volume value and changes
- fixed some memory leak bugs
- fixed a bug with dhcp
Here: [Only registered and activated users can see links. Click Here To Register...]
