AZBox HD Premium
My AZBox Hd Premium is stuck on Booting and I've tried emergency flash with usb noting is happening. I 've tried usb to serial rs232 nothing is happening. I do not know what to do can anyone show me what to do please. unfortunately I only speak english.
Re: AZBox HD Premium
Disconnect the installed internal HDD (if any) and try again emergency procedure with another stick . Don't forget to reformat FAT32 your stick using HP disk storage format tool before u write emergency software on it .
Sper sa nu deranjez postand aici. Nu stiu unde , in ce folder din Azbox HD premium se pun Key. Si cand spun Key inseamna doar acel fisier ".bin" ? Ca am vazut ca se pot pune si softcam.key si Autoroll.key Pana acum m-am descuract de minune cu un dm500. era simplu var/key si var/scce. NU am reusit sa pornesc nici cccam, dar mai incerc in privinta asta am documentatie pe net. Eu am ales calea simpla prin: "SH_v2.0_Install_CCcam_v2.0.4___CCcam_v2.1.1_AZBox_HD" Ma poate lumina si pe mine cineva cu privire la key?
Am rezolvat pana la urma. am instalat mgcamd care cica functioneaza in paralel cu scdxcas.Am si probat, deschide programele codate. am mai instalat multicas, asta mi-a functionat dupa ce am editat manual din telecomanda key -a cu pricina. Am incercat sa convertesc un softcam.key in Key.bin...dar daca dadeam restart la multicas in schimba iar key. CCcam las pe maine..
