Linkul Corect :
http://www.aaf-board.com/wbb2/attachment.php?attachmentid=18196[/QUOTE]
A aparut si versiunea IncubusCamd v0.82 ........ a incercat cineva daca functioneaza si cu Kathrein ?
Linkul Corect :
Il gasiti si aici http://www.sateliti-upload.info//ind...y=Emu/Incubus&
nu cred ca merge pe kathy. e compatibil cu cccam 2.1.0
V0.82
- second try fixing caids tunneling (with PremiereHD card on betacrypt, i can't test it so, i don't know if it works or not)
- first try fixing caid 0603 (same as premierehd, i can't test it, please report if it works or not)
- fixed long ecm bugs
- full support for cccam 2.1.0 protocol
- many minor fixes for stability (hope this version will be better than last one)
KNOWN BUG: sometimes with the timeshift option enabled you can occur problems during standby or channel change,
so you need to restart the cam
available for processor types: sh4 (tested only on Cuberevo family receivers)
Use the e2 version on cuberevo with enigma 2 on board, the other version (*.sh4) on ipbox 9000/900 with dgstation firmwares
Use the sigma version on azbox hd firmwares
Card client for protocols: cccam, gbox, newcamd 5.20, newcamd 5.25, radegast old, radegast new, aroureos
Emulators for: Seca 1, Seca 2, Viaccess 1, Viaccess 2, Viaccess 2.3, Viaccess 2.4, Conax, Cryptoworks, Tps Crypt 1, Tps Crypt 2, Tps Crypt 3, Biss, Constant CW
.conf and .prio files can be inserted in the /var/bin directory, or in /etc, or in /var/keys
SoftCam.Key must be inserted in the /var/keys directory
Has anyone tested IncubusCamd v0.82 on Kathrein UFS910?
IncubusCamd v0.82 works on Kathrein UFS910.
can you please explain how is v0.82 is working on kathrein....
thanks in advance...
No result here .IncubusCamd v0.82 works on Kathrein UFS910
it runs, but doesn't decode, neither softcam neither share...
beeing client to cccam, I don't see how we can talk about share in this case
dm800hd, T90 39E-28E-23E-19E-16E-13E-9E-5E-1W , 37LH4000, Logitech Z-5500 Digital
Only on NEW e2 IMAGES works INCUBUSCAMD!!!!
does it mean that the black pearl is not the newest version?
I got something like>
- Hello01 from
Cards checksum : 01 31 53 B6 08 D9 12
Gbox v2.25
Received 162 cards
Cards on Gbox : 162
-> CR to gbox.****a.**
[Gbox] Connecting to card-server (gbox://192.168.2.25:5566:F*****@tu***
mine.**:5566:*****90)...
-> Hello to t****.mine.** ( ***.0.***.34:5566 )
[Gbox] Successfully connected to server.
SID:1407, NS:0e080000, TSID:000e, ONID:0046, PMT PID:010f, DM:1, DMX:0
Root CA Info | CA Descriptors: 1
CA Descriptor | CAID: 0b00, ECM PID: 0065, PROV ID: 000000
PID Section | Type: 00 [], PID: 010f, CA Descriptors: 1
PID Section | Type: 1b [MPEG4 Video], PID: 0201, CA Descriptors: 0
PID Section | Type: 04 [MPEG2 Audio], PID: 0284, CA Descriptors: 0
PID Section | Type: 06 [Teletext/VBI], PID: 0285, CA Descriptors: 0
PID Section | Type: 06 [Teletext/VBI], PID: 025c, CA Descriptors: 0
PID Section | Type: 06 [Teletext/VBI], PID: 025d, CA Descriptors: 0
PID Section | Type: 06 [Teletext/VBI], PID: 025e, CA Descriptors: 0
PID Section | Type: 06 [Teletext/VBI], PID: 025f, CA Descriptors: 0
cam[di:-]: Selected: CAID:0B00, ECM PID:0065, ECM Table:80, PROV ID:000000
- IAH from
ECM[di:1] **** [Sat Apr 25 15:17:04 2009] Start processing ECM...
CaID: 0B00 - Conax.
Provider ID: 000000 - Supported.
Decoder: Using Gbox protocol card-server.
but no picture at all
card ID:13902, uphops:2, maxdown:0
server: cccam://xxxxx:test@xxxxx.ath.cx:3333333
ECM[di:1] **** [Sat Apr 25 16:27:15 2009] Start processing ECM...
CaID: 0B00 - Conax.
Decoder: Using CCcam protocol card-server.
cam[di:1]: [CCcam] Control words received successfully.
DW network delay time: 273773 us (microseconds).
Control words:
CW0 ( SET): 40 71 A9 5A D9 F6 83 52
CW1 (NOT SET): BE E5 5A FD 75 F9 42 B0
and image on screen!
>zildan
very good... it means that the problem is with my setup.... great.
have you tried with gbox peer?
