felicitari!
foarte stabila,incubus si diablo merg fara probleme
E2_RSP_2.01_TDT884
Stick Image for Kathrein UFS-910 1w or 14w
Imagine de stick pentru Kathrein UFS-910 variantele de 14w si 1w
RSP menu on RED button.
Meniul RSP este pe ROSU
Ce era pe rosu e logic : pe play
Fast zaping
You should keep AC3 downmix ON for stability
It doesn't scan very well. It has a very good list (42E-30W).
We will have frequently updated lists made by EnF70 which you can download from RSP Panel
Zapping-ul este remarcabil la acesta imagine.
Inca e bine sa mentineti AC3 downmix ON pentru stabilitate.
Nu scaneaza bine (astra 28 e dezastru la scanare), are deja o lista buna de canale in ea asa ca merge.
O sa avem liste la zi "made by ENF70" asa ca momentan e ok si asa (stau de TDT sa rezolve problema cu scanatu,
provine de la ultimul upgrade la e2 de DM800 din 9 februarie)
TDT:
PicturePlayer is now hardware-accellerated, currently only jpg support and no thumbnails available picture is always stretched to full screen
Disable stop of polling on CI cams (i know this will make slower E2, but many cams need it like standard require)
Added usb-serial converter support (pl2303, ftdi_sio)
avi h264 support. xvid 720p support.
fix + mv id3tag to eplayer
avi x264 support
Update VFD-Icons crypt symbol and on playback of recordings and mediafiles the play symbol is showed
prepared for dolby symbol and channel name
Changed keymapping, audio and subservice on yellow, aspect on green, see http://img3.imageshack.us/img3/9545/keymap2pi2.png
CSAT France HD Blackscreen Quickfix
Added audio track selection for m2ts/trp/vob, after changing the audio track it might take 2-3 seconds for the sound to continue
PicturePlayer este accelerat hardware. Suporta doar jpg momentan, fara thumbnail, iar imaginea este mereu intinsa pe tot ecranul
Dezactivat (asta va face E2 mai lent, dar este o cerinta standard pentru majoritatea cam-urilor)
Adaugat suport pentru convertor usb-serial (pl2303, ftdi_sio)
suport avi h264, xvid 720p
fix + mv pentru id3tag la eplayer
Actualizate icoanele de pe VFD pentru criptare si playback al inregistrarilor si fisierelor media. Pregatire pentru simbolul dolby si numele canalului
Schimbata maparea butoanelor. Audio si subservicii pe galben, video pe verde. Vezi http://img3.imageshack.us/img3/9545/keymap2pi2.png
Fix pentru ecran negru pe CSAT France HD
Adaugate selectarea pistei audio pentru m2ts/trp/vob; dupa schimbarea pistei poate dura 2, 3 secunde pana reporneste sonorul
RSP
New WEBIF by tic2000
RSP panel rewritten 80%
Intelligent EMU management:
- at every emu install it checks on the server and if there is a new version you can install it
- in the emu start/stop menu you can see only what you have installed
- you can't install an emu if you don't remove it previously (for those already installed of course)
- the partition with the label "RECORD" is automatically mounted on /hdd/movie; the other partition are mounted in /tmp/[device]
- when mounting the HDD you can see only valid Linux partition
- it supports cifs; you have to enable it in the menu and edit the configuration file (var/config/amnt.cfg) with the ip of the pc,
user and password used to login and the folder name you want mounted.
Panel RSP rescris in proportie de 80%
-scalare la emu (se face verificare pe server la orice incercare de install emu si daca apare ceva nou poti sa il instalezi)
-la start stop emu apare doar ce e deja instalat
-nu poti reinstala un emu daca nu ii dai remove in prealabil
=se face automount la partitia cu label RECORD in /hdd/movie
-la montarea HDD apar doar partitiile linux valide (in mod normal ar trebyui sa montati doar sdb..)
-are suport de cifs, se activeaza din meniu si se configureaza /var/config/amnt.cfg pentru a face automount la un director windows
RSP e2 Team
E2_RSP_2.01_TDT884
E2_RSP_2.01_TDT884
felicitari!
MERCI maestre !!!!!
f11
Merge bine pina acum! Multe noutati. Unele schimbari cu care trebuie sa ne obisnuim, dar care sint practice.
Felicitari pt. EMU Menu lui @zildan si pt webif lui @tic2000.
La mai multe si bune!
Felicitari la toata echipa.............si mai ales lui Zildan!![]()
Felicitari intregii echipe si Maestrului Zildan...FELICITARI !!!!!!!!!
THANKS!!!![]()
great job ! felicitari team-ului si multumiri .
Cum se seteaza display time on stand by?Nu reusesc sa gasesc in menu!
Super imagine ...inca o data felicitari...stabila , etc...Cred ca nu se poate seta display time on standby...
Am impresia ca nu prea suporta skin-urile HD...pacat sunt super !!! De fapt nu stiu la mine poate...Oricum imaginea este aproape perfecta...!!!!!!!!
Ne-ar ajuta daca ne-ai spune in ce conditii nu ai reusit sa alegi si sa utilizezi skin HD.
De ce spun asta, pentru ca eu am ales din Menu>Setup>System>Skin... Kerni-HD si imi functioneaza. Are pina si subtitrarea la locul ei. E posibil insa in anumite combinatii sa ajungi la ecrane verzi si resetarea receptorului. Acele situatii, daca le intilnesti, ar fi foarte util sa incerci sa vezi in ce conditii le-ai obtinut, pentru ca apoi, sa incercam sa identificam cauza si respectiv solutiile de eliminare si imbunatatire.
Si eu folosesc skinul dream HD si merge fara probleme.
Subtitrarea pe unele canale de pe 1W este pusa prea jos, iar datorita overscanului TV-ului meu (Panasonic 42PV70) al doilea rand il vad doar jumatate, chiar si dupa ce am ridicat imaginea pe verticala la maxim si am dat V-AMP la -3. Dar acum nu stiu daca e de la skin, pentru ca pe History Channel HD subtitrarea e mai sus, pe Animal Planet HD si Discovery HD e prea jos.
Hi, Thank you for this nice work. Viaccess works without any problem.
I would like to mention two minor things. Luxe HD on 9E not perfect, and when I checked Simul HD on Astra 19E, after two minutes the picture freezed. I had to reboot by manually (switch off-on).
Hi,
unfortunatelly I can't complete the installation of this image; everytime it hangs displaying "WAIT 1 min" in the OSD....
I tried different sticks; different partitions on the stick - even installed after facing the problem again, a different image in the same partionen - the other mage is starting up correctly, but again the WAIT - problem with RSP.
Any idea what may go wrong ?
Regards, flatline
Nu am facut precizari pana acum deoarece nu am instalat imaginea decat astazi dimineata ....ieri am lipsit de la "lansare" ...sunt in teste ....am obtinut pe skin-urile HD niste ecrane verzi, dar nu stiu exact in ce conditii de "frecus"..., fata de skin-ul default unde a boot-at dupa instalare perfect si nici macar nu a necesitat restart din Power....o imagine principala...Astazi testez si va semnalez toate posibilele bug-uri care au un numitor comun....
