Super!! Chiar ma intrebam cand o sa para asa ceva?
Craciun fericit !!
[English]
Description:
A plugin for automatically changing the video mode according to the format of the selected channel.
Install:
1) Copy AutoRes.tgz on Kathy in /tmp
2) Execute: tar zxvf /tmp/AutoRes.tgz -C /
3) Invoke "Restart GUI" from Menu
Config:
Menu -> Setup -> System -> Autoresolution...
Contribution:
I've adapted and tested this plugin for E2 Kathy. (minor changes, just to get it running)
(I've kept the original plugin as 'plugin.py.orig' for reference)
Notes:
1) "iServiceInformation.sProgressive" is not implemented in E2 rev.600 and
hence there is no difference yet between "576i" and "576p" - only one of them will work
720p and 1080i are ok as they don't have both "i" and "p".
2) "576i" cannot be selected as target by default as it's missing from
/usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
You'll need to add this video mode manually if you want to use it:
For instance (in VideoHardware.py)
modes["HDMI"] = ["576i", "576p", "720p", "1080i", "1080p"]
widescreen_modes = set(["576i", "576p", "720p", "1080i", "1080p"])
You'll see that "576i" is not present in these two lists.
(Caution: Some TV sets don't support this video mode)
[Romana]
Se poate folosi acest plugin pentru schimbarea automata a modului video
in functie de formatul canalului selectat.
Instalare:
1) Se copiaza AutoRes.tgz pe Kathy in /tmp
2) Se executa: tar zxvf /tmp/AutoRes.tgz -C /
3) Se da "Restart GUI" din menu
Configurare:
Am adaptat si testat acest plugin pentru E2 Kathy.
Modificari minime, cat sa functioneze bine.
(am pastrat plugin-ul original sub numele 'plugin.py.orig')
Note:
1) "iServiceInformation.sProgressive" nu este implementat in E2 rev.600 si din
acest motiv nu se poate face deocamdata distinctie intre 576i si 576p.
720p si 1080i sunt ok - pentru ca nu au si "i" si "p".
2) Pentru cine doreste "576i" in loc de "576p", acest mod trebuie adaugat in
De exemplu (in VideoHardware.py)
O sa vedeti ca "576i" nu apare in lista (Atentie: unele TV-uri nici nu-l suporta).
AutoRes.zip
Craciun fericit !!
@EnF70
Felicitari !!
Sa iti dau imaginea viitoare sa vezi ce am facut sa iti dai cu parerea la ce ar mai fi de facut.
@EnF70
Thank you!![]()
Felicitari si sarbatori fericite![]()
@EnF70
E facut de tine?
Ca pe AAF-board spun ca e polonez si daca e al tau le dau peste nas imediat!![]()
Nu, nu e facut de mine.
Am scris in primul post ca am adaptat doar si testat plugin-ul pentru E2 Kathy.
In arhiva e un fisier 'maintainer.info' in care scrie cine l-a facut.
Adresa de e-mail se termina in '.de' dar s-ar putea sa fie si polonez baiatu' de l-a scris.
M-am uitat pe AAF Board. L-au copiat de aici ca-mi recunosc modificarile
Poate ar fi o chestie buna sa traduc si-n engleza ce-am scris in primul post.
Era bine sa-ti lasi si tu "amprenta" acolo si sa specifici ca e adaptat de tine pt. Kathrein UFS 910 cu E2.
Intra pe AAF si posteaza pe engleza.
L-am instalat, e prima mea instalare de plughinuri pe Kathrein 910 HD. Merge bine, multumesc.
Nici o picatura de energie nu se pierde in zadar!
Trebuie mentionat faptul ca functia "deinterlacer mod" e activa numai la 50hz.La 60hz e inactiva.
