Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Enigma2 SifTeam Flash Version 0.1.0
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Enigma2 SifTeam Flash Version 0.1.0
    This release is based on the same version of usb stick (0.1.0) but working on flash.
    In this first beta var space is very very little because we have used only jffs2 compression method,but we want to release for people that have problems to install it on usb stick.
    to allow users to modify some files (that with jffs2+squashfs are in read only) such as var/etc/init.d/rcS to start some scripts,like cam,hdparm etc etc.
    If you want to recover some var space delete picon dir and second skin "Vader".
    I think that someone make a little script to move var on usb in a simple way*
    There is a display bug for ipbox900hd release (we will fix in the next release)
    To flash your stb use: rename firmware in usb_update.img and use usb stick with standard flash method . For ipbox9000 you can also use Flashtools and usb cable
    set bootargs in this way:
    setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 rootfstype=jffs2 rw bigphysarea=10240 ip=192.168.1.5:192.168.1.1:192.168.1.1:255.255 .255.0 mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000
    192.168.1.150 is my lan ip
    192.168.1.111 is my serveripaddress (you can set standard value,it's not important)
    192.168.1.1 is my gateway ip (my router)
    255.255.255.0 this is netmask
    that's all
    Thanks to all Sifteam staff
    Upload in progress..................
    asa ca tineti aproape
    02 Feb 2007
    Somewhere in Aegean Sea!!
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    08 Nov 2008
    Default Re: Enigma2 SifTeam Flash Version 0.1.0
    GREAT! Thanks!
    02 Feb 2007
    Ca sa fie instalat asta versiuna trebuie cu null modem cablu sa fie schimbat la bootloader ceva.Asta schimbare sper sa fie facuta de la ABCOM in urmator uboot.Ca sa nu fie nevoie sa il face un user singur.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    05 Jan 2007
    da, scrie aici
    setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 rootfstype=jffs2 rw bigphysarea=10240 ip=192.168.1.150:192.168.1.111:192.168.1.1:255.255 .255.0 mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000
    02 Feb 2007
    Default PKT Panel v3 ENG for E2
    How To Install
    First by ftp enter to var/ and copy there all content from unpacked archive var/ from pc after copy give chmod (attribute) 755 for all files inside folders. Now by ftp copy folder "Fantactic" to: /usr/lib/enigma2/python/Plugins/Extensions/ After this give all files inside "Fantactic" folder chmod 755. Now just restart E2 (restart gui) and have fun with fully translated PKT panel under
    http://www.upload-drive.com/5757/PKT_Panel_v3_ENG_zip
    SI un mod pt cine vrea emu,settings,skin...
    **Asta e raspunsul pentru cei* care tipa la toate lumea ca la kathrein si la ipbox nu se poate enigma 2 in flash.....
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Smile
    salutare la toata lumea imaginea asta noua care se pune in flash a instalato careva daca da poate cineva explica pasii , multumesc
    bootloaderul trebuie pus inainte de a pune imaginea sau dupa
    05 Jan 2007
    Mai intai pui enigma si apoi bootul prin serial ( sau bootezi fara nici o schimbare dar cu setarile implicite ale retelei)
    Wink Re: Enigma2 SifTeam Flash Version 0.1.0
    ok mn mersi de raspuns
    14 Jun 2008
    Baia Mare
    img e aceasi cu cea din varianta USB !din pacate nu are blue panel
    21 Sep 2008
    Cu ce user si pass se conecteaza prin ftp ?
    02 Feb 2007
    am dat mai sus blue panel
    mod PKT
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    21 Sep 2008
    nu reusesc sa ma conectez la e2 prin ftp imi apare in setari la network ip 192.168.1.2 la ping raspunde
    02 Feb 2007
    cum i bagat pe e2 in flash poti sa explici?Ca la mine nu vrea ramune blocat in booting tot timp.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    21 Sep 2008
    rename in usb_update.img apoi am pus stik si am dat update , a pornit cu un ecran verde ca si imaginea de pe stik inainte apoi restart si a mers kiar si alt skin a luat dar nu pot intra in el cu ftp pt a putea pune setings si panel
