Results 1 to 15 of 16
Thread: IPBOX 900 **DGS firmware**
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default IPBOX 900 **DGS firmware**
    Aica o sa gasiti firmware pt ipbox 900HD de la DGS....
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r7043
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r7473
    Official r7473 Cuberevo mini
    added:
    - usb automount function.(9000HD only)
    - Turkish translation.
    - DB updated to R7327. Database will be updated automatically.
    - sorting function in PIP sub-channel list
    - reco***ng file format was changed.(will be applied from new REC. but old format will be played too)
    - using HDD if download large s/w image(for example usb_all_noboot.img).
    Need special server configuration.
    - switch to live when end of file playback
    - improve webinterface function
    fixed,modified:
    - modify tp information. Hotbird 11278 (need DB update)
    - modify many tp information in TurkSat (need DB update)
    - Premiere EPG : show subfeed epg in mainfeed list epg. epg duplication problem.
    - CAM work on backgroud reco***ng.
    - panic if enter wrong format in IP address.
    - remove NTSC mode in AV setting.
    - EPG related panic on some channel
    - support 12h time mode in EPG
    - random panic when play recorded file.
    - improve performance on open FAV menu
    - clear video plan when channel change.
    Warning: If you use USB HDD , you need connect and switch ON HDD before STB boot.
    This version supported only ext2 and ext3 filesystem, HDD with this filesystem will not be formatted.
    If you format USB or e_SATA HDD , STB use ext3 filesystem.
    This version doesn´t supported FATxx file system for photoshow and MP3 playback from USB device saved on PC!
    If you want see Photos, copy pictures to /media/photo.
    ftp login/password: root/ipbox
    Software upgrade from USB memory stick (host):
    • backup important data from memory stick before try to update. Remove all data from it.
    • copy "usb update.img" image to USB memory stick
    • run "remove h/w(memory stick)" function on PC. You can see icon on right bottom (left of clock) screen.
    • turn off the stb(Standby + OK) and insert the memory stick.
    • press and hold Standby button until front display shows “BOOTING” and press UP key
    (on the front side of the box, not on RC), then front display shows "USB UPGRADE" message..
    • uboot will update s/w with usb_update.img from memory stick
    • Wait until DONE message displays. Restart your receiver.
    http://www.upload-drive.com/1336/Cub...473_261519_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8264 mini
    NEW RELEASE r8264: Added or improved Function
    1. The video player(Divx 3,4 and xvid, mpeg 2, H.264)
    : video player can support some file formats such as *.avi, *.mpg and *.mpeg.
    you have to change the extention as *.avi, *.mpg and *.mpeg before playback.
    press pause : pause state
    Pause> pause : pause state
    Play button only can be exit from pause mode.
    Sometimes, If the file needs higher class CODEC than current one, it may be not played.
    If the file itself too high bitrate, it may be not played.
    The version of Divx CODEC more than 5.2 doesn't support it.
    2. WebTV on webinterface
    : First of all, you have to install VLC Player on your PC.
    It's tested on Firefox and Internet Explorer 7.
    Javascript is required.
    Streaming works for 720p channels, but for 1080i there is not enough network bandwidth.
    USAGE: Surf to http://(boxip)/webtv/
    3. ITV HD(Astra 28,5)
    : it should use Advanced Search menu with manually
    (3401 VPID, 3402 APID, 2326 PCR PID)
    http://www.flysat.com/28east.php
    4. improved to related USB HDD
    : 1 channel recording in a TP and 1 recorded file playback or 1 another channel watching in the same TP.
    5. improved channel zapping speed
    6. Solve the bug of the USALS
    7. Solve the bug of the Diseqc 1.2.
    8. Support HDD sleep
    : If select timeshift off, HDD willgo sleep mode after 3 minutes.
    9. Update DB for DVB-T and DVB-C
    : Ireland MMDS(Terrestrial), IRE6887 Quick(Cable), ENG6952 Quick(Cable)
    10. improved to related plugin
    11. channel list of Grid EPG follow channel sorting
    12. bug fixed static IP
    13. Added FAST SCAN function for Benelux
    known issues
    : WSS in Recorded Files.
    : HDMI with compressed Dolby digital audio
    : DVB subtitle
    Above all, we can confirm the effect in the DGSTATION enviroments.
    We cannot be sure of the same result.
    If not so, contact with us.
    e-mail: support@dgstation.co.kr
    cuberevo-mini_r8264.171731.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Re: IPBOX 900 **DGS firmware**
    A aparut azi o noua versiuna pt ipbox 900HD.Fixeze niste buguri.
    http://www.upload-drive.com/3201/cub...264_181602_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8314
    NEW RELEASE r8314: Added or improved Function
    1. Fixed Swaping PIP
    2. Fixed Audio Language Preferences.
    3. Fixed an combination of USALS and Diseqc
    http://www.upload-drive.com/3276/cub...mini_r8314_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8340
    NEW RELEASE r8340: Added or improved Function
    1. Add video resolution in Additional banner
    (press "i" button two times)
    2. Show the kinds of supporting format for video plyer
    (divx, xvid, mpeg, mpg, trp, vob, avi)
    3. Fixed the bug staying power on without signal
    http://www.upload-drive.com/3338/cub...340_232122_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8478 mini
    1. You should download all the attached images in order.
    2. That is better for you to backup channel list using PC Editor before downloading the above images.
    Reference)
    You can get s/w image from http://www.dgstation.co.kr/release/cuberevo-mini_r8478.zip
    Caution)
    1. If you use the software of the previous version, you should dowload the usb_kernel_root_db.img using flashtool via usb cable.
    2. Unplugging the power code may cause serious damage on Cuberevo while usb_kernel_root_db img's downloading.
    Please refer to README file before you start downloading the firmware attached above.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8718 900HD
    DGS release r8718: ( 24/Dec/2008)
    1. Added "post-descrambling with CAM" function on system settings menu
    : When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
    and then you can descramble the recorded file later.
    - The channel in record cannot be watchable.
    - The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
    - even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
    (Caution)
    The recorded file must be performed ˇ°descramblingˇ± before the next smartcard update.
    If descrambling is not running, it is impossible to do the file descrambling anymore
    or able to damage the smartcard since the smartcard has already been updated.
    2. Added HUB function for USB host.
    3. Fixed record programs with DVB subtitle.
    4. Support adjust LipSync using page up/down buttons in Videoplayer
    5. Support NFS function for Linux System in Mount manager
    - changed NFS config in /etc/exports
    ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
    - Removed the firewall of system
    - Removed the firewall of IP table when your system is Fedora
    # iptables -F
    6. Support displays elapsing time on banner of MP3 player
    7. Support Sort function on TMP folder in Recorded files menu
    8. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
    9. Updated language table for Slovak, Bulgarian, Polish and Russian
    10. Fixed DVB EPG bug for HB13 10891
    11. Fixed elapsing time error when schedule recording.
    12. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
    13. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
    14. Added WSS function through SCART
    http://dev.dgstation.co.kr/release/c...718.242042.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8728 900HD
    Th is README is for CubeRevo HD model series.
    This document was approved on 26/Dec/2008 by the DGSTATION.
    DGS release r8728: ( 26/Dec/2008)
    1. Support *.mkv with video player.
    - If the file needs higher class CODEC, the file will not be playback with video player .
    - In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
    2. Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
    3. Fixed some bug for schedule recording.
    4. Fixed record subtitle.
    known issue : DVB subtitle color problem.
    http://dev.dgstation.co.kr/release/c...728.270217.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8873 900HD
    DGS release r8873: ( 22/Jan/2009)
    1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
    press once FF or REW button, the interval is 10 seconds.
    press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
    2. Add Scan option on Channel Scan Menu
    When there is no channel list, all these options create with the same result.
    - Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
    - Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list.
    - Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
    3. Add USB upgrade menu
    - Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
    it is useful for software upgrade with USB morory stick.
    4. Fixed EPG contents Display
    - inserted new line on the screen for EPG and extended EPG information as well
    5. Fixed DVB subtitle - color table
    6. Fixed OSD teletext - some old data not updated occassionally
    7. Fixed wrong duration with the file after schedule recording with EPG
    8. Fixed Local time auto update
    - When the last channel time of the Satellite is different from the STB time within 10 minutes,
    the STB time is automatically adjusted with the Satellite time during the STB booting.
    9. Updated Polish language table.
    10. Updated Web-interface
    11. Fixed small bugs
    known issues : sync with audio and subtitle
    artefact with premiere HD channels from satellite and cable
    no audio with such as Digifilm channel
    adjust color table of DVB subtitle for some channels
    http://www.sendspace.com/file/mczl4c
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    VIP PETER36's Avatar
    18 Jan 2009
    Default DGS r9047 900HD
    DGS r9047: ( 5/Mar/2009)
    release
    1. Added additional channel scan options for TV or Radio
    2. Added repeat function in Video Player
    3. Added navigation method for TTXT sub-channel
    4. Display the summary when searching channel
    5. Save the name of recorded file when user want to schedule in EPG
    6. Fixed bug Toptext navigation with TTXT
    7. Fixed bug which was CubeRevo always blocked when first boot After update
    new software
    8. Fixed bug which was CubeRevo-250HD and CubeRevo-mini were not updated
    local timer after AC power off even with Automatic time setting
    9. Fixed Alphacrypt German Language Encoding bug
    10. Included some of the new plugins in CubeRevo SW version.
    - Thanks as below developper for plugin.
    They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
    dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
    pong, sudoku, tetris, andd weather of Neumoteam.
    11. Updated German language translated by Nilse
    12. Removed subtitle language setting in Language Settings Menu
    users control through subtitle option on RCU.
    13. Modified pop up message 'Service is not available' disappears after 5~6
    seconds automatically
    14. Adjusted the position of Pillar box
    15. Adjusted color table of DVB subtitle for some channels
    Note.
    1. Added Multi booting function
    If you want to multi-boot, download usb_config.img i
    Then press number button on RCU which you want booting mode.
    Multi-booting support as below. Official image is number 3.
    1) boot from cdkroot
    2) boot from USB with hdd
    3) original images
    4) boot from release
    5) boot from USB without hdd
    6) boot from SATA hdd
    7) boot from flash
    2. The Digifilm channel works in official CAM.
    descarga
    02 Feb 2007
    Default DGS r9580
    DGS release r9580: ( 29/May/2009)
    1. Add function displaying time always on Front panel
    2. Add schedule recording title name on webif
    3. Fixed video player panic when spdif is off
    4. Fixed slow icon on TrickPlay and FilePlay
    5. Mapping blue key as check key for 250-hd in filebrowser
    6. Change hdd clean process on hddinit script
    7. Syunchronized sleep Mode as power_control option
    8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
    9. Update tp information Thor0.8W and Astra 19.2E
    10. Fixed many small bugs
    Note.
    1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
    As you know, even if the Filename Extension is different each other,
    if the video codec is same each other, the two files work like same.
    If the video file's resolution is more than 720 X 576, it will works very well.
    So, we recommend below conditions.
    1) resolution : 720 X 576.
    2) FPS : 24, 25 and 30 fps.
    3) Following video and audio codec.
    Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
    Audio Codec : MP2, MP3, AC3
    When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
    If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
    2. ext3 file system is slower than ext2 normally.
    If you record two HD channels with ext3 at the same time, it may fail in record.
    we have checked the speed as below
    ext2 speed : approximately 7MB/s
    ext3 speed : approximately 3MB/s
    Known issues(on going).
    1. Artefact with Premiere HD channels from satellite or cable.
    Caution.
    1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
    2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one
    http://dev.dgstation.co.kr/release/cuberevo-mini/cuberevo-mini_r9580.292143.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
