IPBOX 900 **SIFTEAM firmware**
Aica o sa gasiti firmware pt ipbox 900HD de la Sifteam.
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.1
*From 0.1.1:
**FIRST RELEASE FOR 900HD**
Added jpeg support for background
Added jpeg to base plugin
Add option for umount usb (if
mounted from automount)
http://www.upload-drive.com/1482/usb_kernel_root_db_img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.3
*From 0.1.3:
Modifyed Standby Hard Disk System
From default is 0
For change this value, ..create file:
/var/etc/SifTeam/conf/time_sleep_hd
And add your personel value
Possible value is 12*M (M=minutes)
http://www.upload-drive.com/1483/usb_kernel_root_db_img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.3b
*From 0.1.3b:
*FIRST REAL RELEASE FOR 900HD*
*Sorry for old non work image*
Now have 900HD, test myself
Removed old www (not have sense)
When have time free, make new
plugin for system option
http://www.upload-drive.com/1522/usb_kernel_root_db_img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.4
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.4c
*From 0.1.4C:
Little change in file
/var/etc/rcS.d/S99user_start.sh
http://www.upload-drive.com/1771/usb_kernel_root_db_img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.5
SifTeam-0.1.5-r8022
Based on "OFFICIAL" SVN revision r8022.
*From 0.1.5:
Added panel whit red button
http://www.upload-drive.com/1772/usb_kernel_root_db_img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.6
*From 0.1.6:
Added kneubi script plugin, modified
for new SIF panel system
(Removed kneubi script from online)
Modified more script (for print in LCD)
Added "sdparm" (like hddparm, for USB_HD)
usb_kernel_root_db.img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.7
Sifteam 0.1.7 r8107
*From 0.1.7:
Added more change in any script.
Remove Sif_System plugin
..use kneubi script for default.
usb_all_noboot.img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
SifTeam 0.1.7-r8107 06.10.08
* From 0.1.7 13.10.08
lan bug fixed
usb_all_noboot.img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
SifTeam 0.1.8-r8264 mini
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
SifTeam 0.1.8 r8314 mini
NEW RELEASE r8314: Added or improved Function
1. Fixed Swaping PIP
2. Fixed Audio Language Preferences.
3. Fixed an combination of USALS and Diseqc
http://www.upload-drive.com/3315/usb_all_noboot_img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
SifTeam 0.1.8 r8340 mini
NEW RELEASE r8340: Added or improved Function
1. Add video resolution in Additional banner
(press "i" button two times)
2. Show the kinds of supporting format for video plyer
(divx, xvid, mpeg, mpg, trp, vob, avi)
3. Fixed the bug staying power on without signal
http://www.upload-drive.com/3349/Sif...r8340__900_rar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Member
Beginner
- Rep Power
- 0
SifTeam 0.1.9 r8421 mini
A aparut SifTeam 0.1.9 r8421
*From 0.1.9:
New panel system.
http://www.megaupload.com/?d=5NKVI3NX
SifTeam 0.1.9 r8580 mini
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
