Go Back   RSP Forum > RECEPTOARE > SATELLITE RECEIVERS > KATHREIN > KATHREIN UFS-910 HD > Neutrino
Register Upload Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 11-01-10, 01:30   #1
zildan
RSP - TEAM
Default RSP beta01 TDT1967 Neutrino ufs910
Usb image
RSP Neutrino panel V1 (Menu > Script)
Ecm Icons
Enf70 settings
Emu Download: press Ok and wait ..... and all emu is downloaded, repeat Ok and download all emuconfig
Emu Select: switch emu cyclical (next Ok next Emu)
Emu Start / restart: restart emu or start selected emu (by Emu Select)
Emu List: list installed emu
REBOOT: restart Kathy
For E2 RC k_ey style:
Download k_eys.zip, unzip, copy in /var/tuxbox/config or other folder and go to menu Load K_eis from.
File Type: zip k_eys.zip (424 Bytes, 152 views)
__________________
UFS 910 si altele
zildan is offline   Reply With Quote
The Following 18 Users Say Thank You to zildan For This Useful Post:
amorak (11-01-10), bilyirita (11-01-10), cigla (11-01-10), dbhungry (11-01-10), dreanew (11-01-10), EDW (11-01-10), f.stefan (11-01-10), f11 (11-01-10), fenbg (11-01-10), gatekeeper (20-01-10), iapetos (12-01-10), javier3034 (11-01-10), JoMaDi (22-01-10), Maki_SM (11-01-10), mariuk (11-01-10), monton (12-01-10), vladcarama (11-01-10), znak (11-01-10)
Old 11-01-10, 10:16   #2
papi8
Member
Beginner
thanks for this image
can u post some screens?
rotor is working? and incubus?
thanks for answer
papi8 is offline   Reply With Quote
Old 11-01-10, 10:27   #3
zildan
RSP - TEAM
Neutrino USALS (gotoXX)
Incubus works fine.
__________________
UFS 910 si altele
Old 11-01-10, 10:29   #4
papi8
Member
Beginner
thanks zildan.
i will install it after work.
i dont understand one thing.
i see diferent versions of neutrino, some are tdt and some are GIT.
can u explain me in short what are diferences
thank you
Old 11-01-10, 20:10   #5
guiller
Member
Visitor
Default neutrino
gran imagen que me solventa el problema de las pixelaciones en hd.
muchas gracias al equipo rsp
guiller is offline   Reply With Quote
Old 11-01-10, 20:31   #6
EDW
Member
Beginner
Problems with itvHD (28e)
Longitude and lattiutde settings becomes corrupted.
Cannot exit from EPG.
Cannot scan single transponder, only whole satellite.
Go to X working most of the time, mgcamd working fine.
Cannot mount sda4 for recording.
Good first beta image
EDW is offline   Reply With Quote
Old 11-01-10, 20:33   #7
dreanew
Member
Beginner
Hi
I tested this firmware with a lot of pleasure thanks
the file k_eys.zip is very useful.
Could you help me to manage a parabol with 4 heads with a diseqc 1.0 ?
mulţumesc foarte mult
__________________
Flash : AAF2.e
USB Stick with BA : RSP ( pkt ou AAF) with OSCAM
5°W_13°E_19°E_28°E
dreanew is offline   Reply With Quote
Old 11-01-10, 21:24   #8
alexsan78
Member
Member
eu nu am gasit folderul tuxbox in var
e posibil sa fi instalat ceva resit? sau tre sal fac eu
iar la unsals o ia antena razna
trbuie setat un punct de reper sau asa ceva pt antene mea era pe 1w si setasem motorul tot pe 1w. in momentul in care iam dat sat find trebuia sa ramna pe loc da ...poate cineva care a reusit pm sa pot discuta de amanunte .
alexsan78 is offline   Reply With Quote
Old 11-01-10, 21:25   #9
cristilamb
cristilamb's Avatar
Ca prima impresie:
-high SR cu merge chiar daca pui in rcs high sr=1
-newcs nu porneste :
ufs910:/# /var/emu/newcs -c /var/keys/newcs.xml
/var/emu/newcs: error while loading shared libraries: libcrypto.so.0: cannot op
n shared object file: No such file or directory
ufs910:/#
-pe NDS frameaza la prov. autohton cu mbox din dist.1 la 120-180ms time ECM
mai butonam
__________________
VU+ DUO Kathrein ufs 910+USB HDD+phoenix+smargo+DM3800 Ultra Speedy+Triax 110
cristilamb is online now   Reply With Quote
Old 11-01-10, 21:33   #10
zildan
RSP - TEAM
@alexsan78
il faci directorul, sau pui in alt firector si te duci cu browserul cand incarci setarile de RC.
Vezi ca sageata dreapta face un fel de cd .. daca stii ce e aia.
@cristilamb
Sunt transformari in module si e posibil sa nu mearga HighSR curand.
Nu mai am module pentru adaptorul serial, se pare ca cele puse in imagine nu se incarca.
CIFS nu merge pentru ca nu avem modul pentru noul kernel.
@EDW
Motor-Settings Latitude is set default South
Install new k_eys-map (file is attached at first post)
Manual frecvency scanSCAN!
next step in my study
@papi8
They are mostly similar, GIT is public project bassed on TDT.
__________________
UFS 910 si altele
The Following 5 Users Say Thank You to zildan For This Useful Post:
baqer (18-02-10), cristilamb (11-01-10), dbhungry (11-01-10), EDW (11-01-10), p.irmas (11-01-10)
Old 11-01-10, 21:56   #11
Maki_SM
Member
Visitor
Thx for fantastic img RSP Team
Very stable , mgcamd run fantastic with multiple cws , incubus same problem like with E2
With advanced setings mine 8 LNB's work perfect
Fast channel switching also
THX
Maki_SM is offline   Reply With Quote
Old 11-01-10, 22:00   #12
p.irmas
Member
Beginner
There is no /var/tuxbox/config, just /var/config/ ???
p.irmas is offline   Reply With Quote
Old 11-01-10, 22:19   #13
zildan
RSP - TEAM
__________________
UFS 910 si altele
The Following User Says Thank You to zildan For This Useful Post:
p.irmas (11-01-10)
Old 11-01-10, 22:37   #14
EDW
Member
Beginner
Default Ftp
I am using KCC v3.2, when I FTP to edit file there is error message
'530 please login with user and pass'.
User name 'root'
pass 'kathrein'
is this correct?
Old 11-01-10, 22:41   #15
zildan
RSP - TEAM
Password not needed
__________________
UFS 910 si altele
The Following 2 Users Say Thank You to zildan For This Useful Post:
baqer (18-02-10), EDW (11-01-10)
Old 11-01-10, 23:11   #16
p.irmas
Member
Beginner
What about webif? Other images has it. any plans to include webif?
Old 11-01-10, 23:50   #17
EDW
Member
Beginner
itv HD is okay now.
Technical information (stream bitrate etc.) causes reboot of Neurtino.
Old 12-01-10, 00:40   #18
hd56fox
hd56fox's Avatar
La mine nu a pornit mbox6.10 pana nu am schimbat in mbox6.10.cfg parametrul p:
P: { /tmp/pmt.tmp }
La voi merge altfel ? cu parametrul ca la E2 ? ca nu ar fi normal sa mearga si asa si asa.
Ca nu s-a plans nimeni de mbox pana acu.
__________________
kathy 910,Panasonic,Onkyo TX-SR706,dm800cl
hd56fox is offline   Reply With Quote
The Following User Says Thank You to hd56fox For This Useful Post:
monton (12-01-10)
Old 12-01-10, 02:19   #19
vladcarama
vladcarama's Avatar
Iata shi de la mine unele observatzii:
Inchid reciverul cu 0 volum sonor. Dupa ce restartez apare sunet puternic, apas butonul + de sunet shi ishi revine??? Ceva nu e setat de la Audio seting?
Probleme cu stelitul 36E, nu vede HD-urile de pe el. Cum sa scanez manual transponderii cu HD, adica unde sa indic DVB-S2/8PSK la scanare.
La Video setings este numai scart, nu este shi HDMI?
Cum se shterg canalele din lista, de exemplu de pe 36 E vreau sa shterg totul shi sa pun din nou numai pe cele NTV+, Poverchnosti+, Tricolor TV?
Incubusul merge bine,
dar
Deocamdata raman la E2...
__________________
Nici o picatura de energie nu se pierde in zadar!
vladcarama is offline   Reply With Quote
Old 12-01-10, 06:51   #20
cristilamb
cristilamb's Avatar
P: { /tmp/pmt.tmp }
Asa merge si la mine mbox, am uitat sa precizez, scuze.
__________________
Old 12-01-10, 08:33   #21
papi8
Member
Beginner
hi. u are writing about problems with incubus?
is this problem that in some time picture is like colorful screen with just pixels?
Old 12-01-10, 09:22   #22
amorak
amorak's Avatar
P: { /tmp/pmt.tmp }
inca nu am apucat sa zic eu, dar de cate ori am pornit mbox si am dat pe un canal anume, moare, pornesc iarasi cand dau pe un canal criptat sau nu, iarasi moare, am sa incerc sa pun P: cum zici tu mai sus sa vedem cum e.
__________________
kathrein ufs-910, T90 39E-28E-23E-19E-16E-13E-9E-5E-1W , 37LH4000, Logitech Z-5500 Digital
amorak is offline   Reply With Quote
Old 12-01-10, 15:55   #23
kathrein1
Member
Visitor
Default please..
How i can put inside to nutrino my own List channels , thank you so much.
kathrein1 is offline   Reply With Quote
Old 12-01-10, 17:43   #24
p.irmas
Member
Beginner
Just use Dreamset, choose neutrino plus in settings
/usr/local/share/config/ for sttelites
/usr/local/share/config/zapit/ for bouquets
Old 12-01-10, 17:54   #25
hd56fox
hd56fox's Avatar
Wrong !
Must neutrino plus hd (api3)
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Design By: Enrique
Powered by Romanian Satellites Provider
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Romanian PC Forum! InfoSatelit Digital Satelit
Shop Catec
Opticum Systems Todo Dream Elstar
Free PageRank Checker
