Results 1 to 2 of 2
Thread: How to get working a cheap ID cardreader Omnikey o
    13 Feb 2007
    Earth
    Post How to get working a cheap ID cardreader Omnikey o
    How to get working a cheap ID cardreader Omnikey or SCM with NewCs under linux
    How to get ID cardreader Omnikey 1020, 3021, 3121 or SCM SCR3310 to work as sat smartcard reader with newcs.
    1: A cheap USB identity cardreader Omnikey or SCM both works fine. I self have tested they. And they cost around 6.- to 9.- euro. But they are not working with other cams!
    2:You need "pcsc" version of newcs. Exmple u have PC linux server, then you need newcs.i686.pcsc Download link: Index of /arsiv/cardsharing/newcs
    3: Next we need install drivers for these readers.
    OpenSC install under Ubuntu/Debian
    Fedora Core way:
    su -
    yum install opensc pcsc-lite ccid
    chkconfig pcscd on
    service pcscd start
    Debian way:
    apt-get install opensc pcscd libccid
    Ubuntu way:
    sudo apt-get install opensc pcscd libccid
    Next command:
    nano /etc/opensc/opensc.conf
    And change thise lines by removing # from front and reader_drivers lines u delete one comand too:
    reader_drivers = pcsc, ctapi;
    try_emulation_first = yes;
    lock_login = false;
    If that is done hit from keyboard ctrl+o and enter, then ctrl+x to exit
    Next give command:
    opensc-tool --list-readers
    And you should see your reader there present like so, but with your reader info. Examlpe Readers known about:
    Nr. Driver Name
    0 pcsc Omnikey 1020
    4: Sample newcs.xml config:
    <?xml version="1.0"?>
    <newCSconfig>
    <readers name="Omnikey">
    <device>
    <name>Omnikey</name>
    <type>pcsc</type>
    <mhz>368</mhz>
    <node>pcci</node>
    <parity>odd</parity>
    <reset>normal</reset>
    <export>Yes</export>
    <enabled>Yes</enabled>
    <blocksa>No</blocksa>
    <blockua>No</blockua>
    <blockga>No</blockga>
    <blockC0>Yes</blockC0>
    <carddetect>no</carddetect>
    <newcamd_port>15050</newcamd_port>
    <autosid>Yes</autosid>
    <pincode>0000</pincode>
    <priority>round</priority>
    </device>
    </readers>
    <radegastserver>
    <port>10001</port>
    <allow>
    <hostname>localhost</hostname>
    </allow>
    </radegastserver>
    <cache>
    <emm>20</emm>
    <ecm>-1</ecm>
    </cache>
    <httpd>
    <server>
    <port>8080</port>
    <enabled>yes</enabled>
    </server>
    <user>
    <name>newcs</name>
    <password>newcs</password>
    <accesslevel>admin</accesslevel>
    </user>
    </httpd>
    <debug>
    <password>NewCSpwd</password>
    <mode>simple</mode>
    <level>internal</level>
    <type>all</type>
    <output>console,tcp</output>
    <tcp_port>1001</tcp_port>
    <tcp_options>normal,init</tcp_options>
    </debug>
    <newcamdserver>
    <name>newcs</name>
    <user>
    <name>dummy</name>
    <password>dummy</password>
    <au>on</au>
    <sidoverride>off</sidoverride>
    <spider>No</spider>
    <cardlevel>1</cardlevel>
    </user>
    </newcamdserver>
    <chameleon2>
    <server>
    <port>1234</port>
    <realm>myShares</realm>
    </server>
    <peer>
    <hostname>remote</hostname>
    <port>1234</port>
    <name>myname</name>
    <password>mypassword</password>
    </peer>
    <user>
    <name>myname</name>
    </user>
    </chameleon2>
    </newCSconfig>
    Note:
    <node>pcci</node> you use if u have ID reader and smargo same time attached to same PC, then ID reader uses path pcci. Other way smargo does not work anymore!
    <node>0</node> , <node>1</node> what usb port u use. If u have ID reader without a smargo attached. Yes u can add more as one ID reader to your system then just adjust correct usb node path to new reader. To determine correct new attached reader path use command:
    lsusb
    Example setting if in CCcam is smargo and in newcs is ID reader:
    SERIAL READER : /dev/ttyUSB0 smartreader+
    Then ID reader goes to usb2 and with
    <node>pcci</node>
    If u do so then your both readers as smargo in CCcam and ID reader in newcs come up.
    ID readers can mostly overclock up to 9mhz same way as smargo or reciver internal reader. ''
    28 Sep 2009
    Default Re: How to get working a cheap ID cardreader Omnik
    hello
    why do we need to insall opensc?
    the reader works without it.
    Are you sure you can clock the reader? if yes please tell us in wich way you do it
    regards
