Results 1 to 7 of 7
Thread: DM 800: Sid not found in Pat
    13 Feb 2007
    Earth
    Post DM 800: Sid not found in Pat
    '' If you find these messages annoying, you can turn them off by editing:
    /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
    You can comment out the lines with a leading Hash #..
    #eDVBServicePMTHandler.eventNoPAT: _("No data on transponder!\n(Timeout reading PAT)"),
    #eDVBServicePMTHandler.eventNoPATEntry: _("Service not found!\n(SID not found in PAT)"),
    #eDVBServicePMTHandler.eventNoPMT: _("Service invalid!\n(Timeout reading PMT)"),
    Once you make your changes, you will need to reboot the box so it can compile the python again..
    However, I must warn you that you won't recieve these messages on screen when there is a real issue, not just that the channel is not broadcasting it this time.
    I've only done this it's is really annoying when flicking through the channels and the message screen appears and you have to hit ok... to continue flicking... ''
    16 Sep 2007
    Default Re: DM 800: Sid not found in Pat
    Regula 12
    Multumim de toate informatiile ce le aduci pe forum.Dar pentru "tune failed " inca nu ai gasit nimic?
    23 Apr 2008
    Bucharest West
    Regula 12
    Merci si eu!
    sau pentru trecerea de la sky ita HD, de la un TP la celalalt, tot tuned failed, stie cineva ce si cum?
    trebe sa dau pe alt satelit si sa revin la sky ita ca sa mearga...
    灌水 expression's Avatar
    09 Oct 2008
    PL-RO
    Eu am gasit un InfoBarGenerics.py gata modificat, dar face crash enigma cu el, chiar si daca apas tasta "menu". Poate varianta ta e OK. Incerc diseara.
    The quieter you become, the more you are able to hear...
    27 Feb 2007
    Valcea
    Deasupra celor 3 linii este si linia Tune failed care la fel poate fi dezactivata.
    Se pune # si spatiu inaintea celor 4 linii.
    43 Post(s)
    "Sid not found in pat" nu este un defect al receptorului.Unele posturi de televiziune transmit doar intre anumite ore. Acest mesaj de eroare apare cand pe acele posturi nu este emisiune.
