Page 1 of 5 12345 LastLast
Results 1 to 15 of 70
Thread: Hadu - CCCam
    Standard RSP member melting's Avatar
    19 Sep 2008
    Default Hadu - CCCam
    http://www.easy-share.com/1906153290/Hadu - CCCam DVB plugin - v Beta 0[1].100.rar
    [Serv_1]
    Server=CCCam:MyServer.com:12000:0:MyUsername:MyPassword
    11 Apr 2008
    Fost mebru
    Default Re: Hadu - CCCam
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    daca dai click pe Link Direct iti da acelasi lucru. nu era o intrebare pusa de delta2k2
    Golden Member gigelsat's Avatar
    Se pare ca asta chiar merge.
    Gigel
    Pentru ca am fost contactat pe pm de colegi care nu au reusit sa porneasca acest hudu-cccam, fac aici precizarea care de altfel este explicita mai sus ca linia de la flaycccam nu se potriveste exact aici ci are o forma putin modificata:
    la hudu e asa:
    la flayccam ar fi asa:
    C: MyServer.com 12000 MyUsername MyPassword
    Deci sunt exact aceleasi elemente, doar ca trebuie puse putin altfel.
    Gigel
    11 Apr 2008
    Fost mebru
    Post Update 0.101
    O nouă versiune , Beta 0.101
    Pentru download direct apasă AICI
    Changelog :
    -new modification to process NDS/Videoguard ECM still a bit faster. Be sure to use and to configure correctly your DVB application, in order it can deliver one TS at a time to its plugins (i.e. packet size=184 bytes). And always uncheck the "Log Messages" menu in case NDS/Videoguard ECMs, if you don't want to get glitches,
    -modification to allow the "special" NDS/Videoguard ECM process, in case of DVBCore plugin,
    -several fixes concerning the multi-servers feature,
    -fixes for incorrect ECM results display and Server infos display, in different cases,
    -bug fix if no ECM stream present for a valid PID declared into PMT,
    -a few minor enhancements: explicit message when the same server ( = same IP address and same port) is already in use, Server infos window no more centered for each subsequent calls, ...
    -correction when stopping and restarting a server while being on an encrypted channel,
    -start/restart process enhanced. After 3 consecutive negative tries, the restart process is made: 1 second, then 2 seconds, then 4 seconds, ... then 32 seconds later; with a maximum of 32 seconds between each restart call. However, a manual start is always processed immediately, regardless of the current delay between 2 restart calls,
    -various internal bug fixes and minor modifications,
    -complement of informations in some parts of the readme.txt file.
    11 Apr 2008
    Fost mebru
    O completare :
    in noua versiune a fişierului Hadu.ini , lipseşte opţiunea [Serv_1] , care preceda linia de configurare. Fără această opţiune , pluginul este activ , dar nu comunică corect cu serverul de CCcam.
    Deci , fişierul Hadu.ini trebuie să arate in felul următor :
    Code:
    [General]
    PluginActive=1
    KeyPath2=
    [Options]
    UsePSITables=1
    SurveyPMT=1
    UsePATforPMT=0
    DontUpdViewer=0
    UseDVBTime=1
    MaxECMPIDs=4
    MaxConnections=4
    LogMessages=0
    LogMessLevel=1
    [Specific]
    DVBViewerAPI=0
    DVBViewerAllAudio=1
    DVBViewerCSAStat=0
    [Device]
    MDRoot=0
    DescrCommand=
    XorEven=
    XorOdd=
    UseTT=0
    [Serv_1]
    Desigur , la ultima linie (cea cu Server=CCCam: ...) fiecare işi pune setările personale.
    Varianta mai simplă ar fi să păstraţi vechiul fişier Hadu.ini
    19 Sep 2008
    Hadu - CCCam DVB plugin - v Beta 0.102
    http://www.fileshare.ro/1266740677.85
    0.1.0.2:
    -correction concerning the internal CSA support (DVBViewer plugin). Don't use it unless absolutely necessary, especially for HD channels. Prefer the CSA.dll/FFDeCSA.dll (both of them) instead (see DVBViewer section),
    -bug fix for incorrect accepting of some certain kind of nodes.
    Standard RSP member disat's Avatar
    19 Feb 2009
    nu merge ir''to
    19 Sep 2008
    Hadu_CCCam_DVB_plugin_beta0.104
    http://www.flyupload.com/?fid=561527530
    0.1.0.4:
    -another modification concerning the "wrapper" applications like SSSP Plug, ... Remember to set "UsePSITables=0" (or uncheck the corresponding menu entry) and "ECMTimeOut=12" (for instance) for these applications.
    0.1.0.3:
    -DCWs display added into the CAID list. This display corresponds to the last DCW(s) received; which doesn't mean necessarily the current one(s),
    -all the windows of the plugin can now be minimized (and restored). The "Monitor" and "Server Infos" windows are also now resizeable (only the horizontal sizing is used; mainly to have a wider area for the lists of data),
    -choice to display IP Address or URL in the Server list has been added. The default option is still to display the IP Address (see DisplayIPorURL option),
    -the refresh time for the Server infos has been set to 4 seconds,
    -bug fix concerning the node disconnection treatment,
    -still another bug fix for incorrect accepting of some certain kind of nodes,
    -an ECM timeout option has been added (see ECMTimOut option). It's mostly to be used with "wrapper" applications like SSSP Plug, ... As I cannot test these kinds of application, I don't know if this feature is sufficient to make my plugin compliant with them,
    -node ID display added into the nodes list (last columns)
    11 Apr 2008
    Fost mebru
    Default Hadu CCCam DVB plugin beta 0.105
    O nouă versiune , Beta 0.105
    Bug fix for Cryptworks "long" ECMs (for Digiturk mainly)
    19 Sep 2008
    Default Re: Hadu - CCCam...0.1.0.7
    Versiune noua .......
    Download
    0.1.0.7:
    -bug fix for a incorrect CAID selection process, introduced into the 0.1.0.6 version. It mainly concerns all the Seca providers (but could have a negative impact for all the others CAIDs too).
    0.1.0.6:
    -number of disconnections column added into the nodes list,
    -"NoNodeCAID" option added, to ignore all the nodes or only one node of a server,
    -CAID tunneling added for Betacrypt<--->N3 CAIDs (see "CAIDTunnel" option). Do use CSa.dll and FFDeCSA.dll, if you plan to view Brumiere HD channels with DVBViewer
    19 Sep 2008
    Default Re: Hadu - CCCam...0.1.0.8
    http://www.fileshare.ro/1284591053.2
    0.1.0.8:
    -the way to ignore/use an available node has changed: right-click now on the node to get the corresponding menu (currently limited to this feature only),
    -because of the tremendous number or disconnections/re-connections of some nodes for most of the CCCam servers (especially, but not only, those of version 2.0.11), the restart of the CAID selection process is no more always called. Unless no nodes have been found to decode the current channel; in this last case, the restart is still automatic. In some rare cases, you may have to ask manually to retry all the ECMs,
    -Irdeto ECMs are now sent to the CCCam server(s) one at time only (though still currently a workaround),
    -a new modification into the CAID selection process, to increase the stability of the decoding process.
    19 Sep 2008
    Default Re: Hadu - CCCam....0.1.0.9
    http://www.fileshare.ro/1293339284.18
    0.1.0.9:
    -automatic detection for sssp "wrapper" application (if it's called ssspxxxxxx.exe). In this case, the command to return DCWs to the application is modified (i.e. $0410 instead of $0700). However, you can always force it, using the "DescrCommand" option into the "[Device]" section of Hadu.ini,
    -modification to stick as tight as possible to the answer of the server(s) concerning the ECM requests. It may have some negative impacts in some rare situations. In these later cases, atop and restart the concerned server connection,
    -new modification for Irdeto ECMs. Only the first positive ChID (i.e. available for decoding purposes) is used, after a first test with all of them.
